I just bought a quickfix complete singer sewing machine and either i cant figure out how to tread it or it just keeps jamming. how do i make it so it wont get jammed?
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin as there could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
* When you start to sew a seam, Hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting jammed in your machine.
If your Singer Heavy Duty 4423 is jamming when you try to sew in reverse, it may be due to a few issues:
Thread tension: Make sure your thread tension is not too tight, which can cause the thread to bunch up and jam the machine. Try loosening the tension slightly.
Needle: Make sure you are using the correct needle for the fabric you are sewing. A dull or damaged needle can cause the machine to jam.
Bobbin: Check your bobbin to make sure it is threaded correctly and is not damaged.
Machine maintenance: It's important to keep your machine clean and well-oiled. A buildup of lint or dirt can cause the machine to jam.
Sewing speed: Slow down when sewing in reverse. Sometimes going too fast in reverse can cause the machine to jam.
If none of these solutions work, it may be a mechanical issue with the machine and it's best to take it to a professional for repair
Hi . try adjusting the tension screw on the bobbin case on the thread tension leaf . tighten it slightly just enough that the thread needs needs a little bit of nudging to come out . do the same for the thread coming through the needle . this should help .
I would say that the threading is wrong somewhere, watch your dvd and read the owners manual, also go to Singer.com FAQ for your machine, If the jamming is underneath, it is the top threading problem, on top, it is the bobbin thread either has lint or stray thread or thread not coming out the right direction for your bobbin, I am sure that it is just a simple solution, I also use metal SA 156 bobbins and have no problems,
There might be something jamming the petal open so it won't slow or stop when you put your foot on it.. I would try that, get some canned air and blow it out and see if it helps.
To learn how to solve bobbin jam and select the correct needle, I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional step-by-step repair guide written by an expert. Besides Singer sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
