Question about Car Audio & Video
My Phase Linear UV7il accept only some CD's
My Phase Linear UV7i will accept some CD's, but for some reason it will not even let me put in some other CD's. I've been trying to insert memorex CD-R 52X CDs, and it will not even go in, it just says ''eject''. The CDs look the same size and same width as any other CD-DVD; why is it doing this?
  • Anonymous Dec 29, 2009
    Thanks for your input hoboman3. I found a way around the problem last night. It seems the read light is so sensative that if there is even one minute of unused space on the disc, it will not let me input it for play. So, I just exceed the recording time, so that the disc is full, and my last song usually cuts off (so I make sure it's not one of my favorites...). Not a real technical solution, is it; but it works.
    New Friend:
  • 37 Answers
The head unit is not reading due to incompatibility with thebrand or type of disck
Posted on Dec 29, 2009
  • Paul Reese Dec 29, 2009
    hey, at least it works. glad you fixed it. :)
My UV7i just opens and closes as it pleases
Some loose connection on the LCD panel to the device, or inside the LCD, by a certain vibration the monitor seems to get like a christmas lights one on/off..
you better bring it to a certain service technician to provide through test on your device.
thanks
Feb 23, 2008 | Phase Linear UDV9010 Car DVD Player
How to assemble the phase UV7i dvd/cd player
can u give me some info about how to identify the power supply wire to a car cd player
Jun 27, 2009 | Phase Linear UDV9010 Car DVD Player
I have the phase linear UV7i I was trying to put in the overide
reset it,try with out the remote and change the remote battery,put in dvd wait for the blue screen,then press stop 2x then enter 1264 then,if you have a up,down,l/r control on the deck press down 1x then press play,you dont even have to use the ground wire then go to the rest, when you can see the menu,i dont know if it will work but u can give it a try
Jun 18, 2009 | Phase Linear UDV9010 Car DVD Player
How can i watch dvd while i drive?
its very sample. you will insert a DVD and everything will be start and going automaticly.
May 29, 2009 | Phase Linear UDV9010 Car DVD Player
Phase linear UV7I
I Need Phase Linear uv7i Owners Man. Also Vol. Control Goes Up As You Turn It Down. Repairs??? C/D Dvd Not Working! Help!
May 27, 2008 | Car Audio & Video
Phase linear uv7i
RUN A TOGGLE SWITCH FROM THE PINK WIRE AND THE OTHER END GROUND IT PUT DVD IN FLIP SWITCH 2OR3 TIMES YOU SHOULD BE ALL GOOD
Dec 28, 2007 | Alpine CDA 7893 CD Player
Phase linear UV7i makeing the dvd player without useing parking
There is a pink wire that goes to the parking brake. It connects to the ground wire on the parking brake that makes the brake light come on the instrument panel.
connect the pink wire on your stereo to a frame ground.
Oct 28, 2007 | Car Audio & Video
Car Audio & Video Logo
208 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Mark Skinner
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
