LG LMV2083SW Microwave Oven Logo
Anonymous Posted on Dec 29, 2009
Hi there, I'm installing an LG LMV205SW OTR Microwave and the four holes for the mounting plate do not coincide with the two wall studs that are behind the microwave location. Can I sink a couple of extra lag screws through the mounting plate into the studs in addition to the other four corners on the template?
Anonymous
Level 2:
Scholar:
  • Expert 142 Answers
  • Posted on Sep 27, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
142
Questions
Helped
28075
Points
437
It does not really matter where you can get a lag screw into a stud as long as you can get at least two screws in place holding the mounting plate. Don't forget there are two screws in the front you have to put in.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 382 Answers
  • Posted on Dec 29, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
382
Questions
Helped
125786
Points
866
Consider the studs as I I add 2 2x4's like in an H with second 2x4 below the cenre bar in the H adjust both to the spaces needed for your mounting crews if it came with a template use it....I am not a carpenter but It Is what I would do
Can I reuse a microwave mounting plate
Without seeing plates it is hard call. personally I would remove old plate and install new plate in accordance with instructions. You want to not void warranty by using old plate. There should screws into the studs this is the desired mounting. You can use your knuckle and tap across the wall, when you reach stud the sound will be different. Good Luck
when I replaced MW units for customers I always used supplied parts. I have also been called to correct installation by store. the people they sent should not been allowed to attempt the project ( I didn't mind as i charged for my time and tools and knowledge.)
1helpful
I removed the bolts for my Danby OTR microwave. Dmw162w-otr. The microwave does not move. Are there any other bolts or is there anything I am missing before I can remove the microwave?
In a normal installation, there is a plate that mounts to the wall and bolts come down through the cabinet. Once the bolts are removed from the cabinet above mic, the mic should hindge forward. It takes two people to handle. How ever, in some cases an installation guy will add screws into the side of the unit. So look for some screws to the right and left of mic. Good luck!
Can you provide guidance on how to install this microwave? Trying to decide if I should pay $120 for the store to install.
Installation of an over the range microwave is not a very difficult task as long as electrical work to provide power is not needed. If no outlet exists then an electrician will be required.
Tools that may be needed for the installation include a cordless drill, drill bit, measuring tape, masking tape, stud finder, razor knife, pencil.
A template is commonly provided for mounting hole locations that need to be drilled in the cabinet. These holes are the top mounts.
An additional template for the wall bracket is normally supplied as well. Here you will need the stud finder, it is important to locate the studs and mount the wall bracket to them.
The wall bracket serves as the bottom mount and aids in the final mounting of the microwave.
Depending on the oven's size and weight a helper may be needed to complete the installation.
Remember to be safe first and seek advice/help with any step you are unsure about.
Good luck.
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
1helpful
Need to install goldstar mv1515b otr microwave but do not have mounting kit. Where to buy? what does it look like? can i make a mount for it?
you can not get a plate . only plate that mounts it is the one that came with it . now I did this with my own sharp and this wil work with any . cut the wall benind same size of micro / this will let you slide it into the wall almost 3 in . giving you more room to cook and work on range top. she loved this . then attach the front by the bolts from the top or screw/s to the side of both .. makes a neet install ..****/ feed back pls .. dont forget the power goes in the top ,,
3helpful
Need installation instructions for otr microwave please
I just pulled my ge spacemaker xl1800 out. The mounting plate installs on the wall and two 4-6 inch bolts go through the cabinet above and into the top-front of the unit. The two top mounting holes are about 8 1/2 in. from the back of the unit and about 1 1/4 in from the side. If you don't have the mounting bracket that comes with the unit, you will have to use a 2x4 or similar to support the back & bottom of the unit.
Mounting OTR microwave oven under a penisula cabinet
We put false doors on the back of the peninsula, mounted the wall mounts on the inside of these doors and then connected it to the top.
One stud in the middle for an OTR Microwave Install?
i had the same trouble, yes i used a solid bolt to hold the microwave bracket in the stud then used the biggest toggle bolts that will fit, also the cabinet will not have to be changed. it works fine, if you had a vent a hood dont forget to hook up the exhaust vent. i figure your old exhaust vent is in the cabinet like mine was
2answers
No studs for microwave installation
There has to be something in the wall supporting the drywall. You need to find the supporting structure using exploritory holes if necessary and solidly fasten to it using lag bolts.
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
