Hi There
I found this for to read to help you on your problem hope this helps.Let me know how it goes.
If
the washer doesn't reach its proper spin speed, the clothes may be too
wet at the end of a cycle. Check to be sure the load is properly
balanced and run a spin cycle again. If the clothes are still wet, you
may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®),
or a worn motor pulley or tub bearing. Replace the applicable
component.
Thank you for writing to fix ya.
Best Regards Richard
Testimonial: "Good advice. The washer was just out of balance. Thanks for the fast accurate response. Dennis"
