Question about Sterling J3E Hamilton Antique Pocket Watch
Watch is fully wind up but doesn't run?
My Hamilton pocket watch is fully wind up but doesn't run?
Posted by asepsi on
Anonymous
  • 714 Answers
Several solutions:
Needs cleaning is the best possible reason.
Broken balance due to being dropped is second.
r/
David
Posted on Jan 22, 2010
How can I set?
Shirley, RE POST make model # and your complete question, so we at Fixya can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 17, 2016 | Watches
Brand new Hamilton automatic watch, but we can't get it started running.
If this is a self winding watch then you will have to rotate the pendulum inside it about 200 times before it will start. The directions should show you the proper way to rotate the watch to move the internal mechanism.
Dec 25, 2012 | Watches
Is it possible to convert a wind-up watch to battery(quartz ?) operation ? Thanks.
Unfortunately no, the only option is to remove the mechanical works and replace it with a quartz circuitry.
Sep 26, 2011 | Sterling J3E Hamilton Antique Pocket Watch
How do I set the time on an old Regina pocket watch. I can wind it and it runs well. The piece to wind the watch does not pull in or out to set the hands.
If you can wind your pocket watch using the crown, but you cannot see any way of setting the watch, you probably have a "lever-set" movement, though it's possible you might also have a "pin-set" movement. Do you see a little button you can push in, either at 1-2:00 or 10-11:00 on the watch case? If you, you have a pin set watch. Push and hold that little button in while you twist the winding crown, and that will let you set the time. End of problem.
Setting the time on a lever-set watch is a bit more complicated and will require taking off the front bezel of your pocket watch--the metal ring that holds the watch crystal in place. Pocket watch cases of this time are usually made in 3 pieces: the bezel, the main case body, and the back. The procedure used to remove your bezel depends on the type of watch case you have.
Take a close look at the front of your pocket watch. Do you see any hinges at the bottom (that is, below 6:00 and where the bezel meets the main case body)? I suspect that you won't, as double-hinged cases are usually associated with an older style of pocket watch, but it's worth checking. If you do see little hinges for the FRONT (it's more likely that the back will be hinged), then look for a little lip on the bezel that's used to pry open the front. Pull on that to open the case.
If you don't see hinges, which is what I expect, your front bezel unscrews. You can try to do this with your bare hands, but it's a lot easier if you have a bit of "gripping" rubber so your hands don't slip so badly. I have a small rectangle of shelf non-slip stuff that works perfectly for this. Turn the bezel counterclockwise. It may resist a little bit at first due to accumulated dirt, but then it should easily screw off.
Once you have the bezel away from the face, look closely at about 2:00 on the watch dial. Just at the edge of the dial, you should see a little lever or button. GENTLY pull this away from the watch face until it stops. Now, when you turn the winding crown, you should be able to set the time. Once the time is set, gently push the lever back to its prior position. Now, you should be able to wind the watch without changing the time.
Be very careful when screwing the bezel back onto the watch body. These parts typically have very fine threads, and it's easy to cross-thread the pieces. Don't force the two pieces together; once the threads catch properly, the front bezel will screw on easily without resistance.
An older style of pocket watch required the use of a little key to set the time from the back of the pocket watch movement. However, these watches were also wound by the same key, so the fact that you're able to wind this watch with a crown suggests to me that your watch doesn't use this system.
May 27, 2011 | Watches
Watch will not wind and will not run or keep time. It appears to have over wound itself.
Not possible. The assumption that a watch is fully wound and then doesn't run is because the watch is over wound is invalid. The correct assumption is the watch has been fully wound and the watch has a problem. Could be anything. Automatic winding watches have a mainspring that slips or acts as a clutch when fully wound to avoid breaking from continuous winding.
May 23, 2011 | Stuhrling Emperor Watch
How find serial number on ~1910 hamilton pocket watch?
The serial number is usually engraved on the movement. If you open the back of the watch, you should be able to see it.
I looked at the Hamilton pocket watch site (in might be helpful if you visit the site, simply type "hamiltonpocketwatches.com" into your search engine and your will be able to examine photos of a number of movements).
The position and size of the number varies but it shouldn't take to long to find. One of the pictures I found impossible to see the number but the rest I found, although sometimes you had to look quite carefully.
Jan 29, 2010 | Sterling J3E Hamilton Antique Pocket Watch
How do you know when you've wound a 1926 Waltham watch enough?
If you wind it gently, (do not apply a great force), it will slip in you fingers when it is fully wound.
If it stops frequently, it could be that it needs cleaning. As it is a very old watch, specialist advice might be worth paying for.
Good luck
Dec 28, 2009 | Watches
I can't get my hamilton watch to open. I pulled out the wind knob and heard the click, but can't find any hinge or any other way to get it open. What am I doing wrong? Thanks
If your watches case does not have a hinge then pulling the crown out won't do anything but allow you to set the time if it is a stem set watch. If it is a lever set watch then the lever which is under the bezel will need to be pulled out before you can set the time.
On a pocket watch without a hinge the case back and or bezel will unscrew from the case.
Hope this helps,
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 01, 2009 | Sterling J3E Hamilton Antique Pocket Watch
Antique Hamilton pocket watch how to open? I unscrewed the face and see a notch at the bottom and a hinge on top of face. I tried prying upward at notch but it did not want to open. I was applying enough...
Pull the wind knob out...it takes a firm pull on mine. You will hear it click, then you have room to pull the movement out towards the hinge. Then close when done, and push the wind handle back in.
At one oclock the lever is pulled out about 1/4" then you can set the time, when finished, push the lever back in.
Hope this helps...george
Jun 13, 2009 | Sterling J3E Hamilton Antique Pocket Watch
Sterling J3E Hamilton Antique Pocket Watch Logo
566 people viewed this question
Top Sterling Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Sterling Watch Expert? Answer questions, earn points and help others
