Try taking out the power cable from wall and the plug it back in and keep hitting eject if it does not want to then unfortunatly there is noway to get it out unless it was forced out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
If all else fails...you may have to go inside and take a look. I had this happen to me and after I removed the cover I found that a very small piece of plastic had somehow gotten into the moving parts and kept them from operating correctly.
Before opening the lid...remember to first UNPLUG the unit and don't touch any of the electronic parts/pieces unnecessarily. You're just looking at the VHS ejection mechanical parts at this point. If you don't see anything obvious that could be causing the problem, (if you can do this with any level of confidence) then plug the unit in and try ejecting the tape again. Watch for anything hanging up all the moving parts that move to physically eject the tape.
Again if you're at all not comfortable working around something like this with live power....then DON'T DO IT! Take it to have it looked at professionally.
But if you are OK doing this sort of thing, hopefully you'll see some piece of junk has fallen into the tape area and it jamming it up and keeping it from working. The piece of plastic that was blocking my tape deck from ejecting was so small that there was NO WAY I could have seen it looking through the tape door.
Hi, i would suggest that if the above fails try looking at the tape by lifiting the front flap from where the disk is inserted, if you can hear the motor trying to push and when you hear it try to reach your fingers to the tape and lift it up and the tape should pop out...and be careful doing it and as soon the tape starts to come out remember to keep the front flab lifted up and remove your fingers out of the way of the tape of the the motor would understand ur trying to push it back in and take it inside again...and whishing you best of luck and do let me know if this works if it still doesnt, i shall help you with some other option without having to rip it apart...and man i really appericiate your love for ur player mate and i will try my best not to disappoint you..cheers.
Okay try this unplug it leave it for five minutes then plug it back in and try rewind then eject ..i know this sounds silly but if you have a belt slipping this could work..turn the machine upside down and try eject.if none of this works you'll have to take it to an expert..ps don't be tempted to force the deck in anyway as this will damage the vcr and tape .hope you have some luck farr64[colin]
I got my tape out very easily. It is almost like the mechanism that loads and unloads the tapes is not functioning. But now I cannot get a tape to load.
