Computers & Internet Logo
Question about Belkin Wireless G Plus MIMO (F5D9010)
How do i connect my verizon dsl westell 6100 to my belkin g rtr?
How do i connect my verizon dsl westell 6100 to my belkin g router for internet sharing. my modem is currently connected to the computer via a usb. if i connect the routers ethernet to the modem, there is no connection wire to the computer. help, please and thank you.
Anonymous
    New Friend:
Wellll....since it seemed an impossible task, I tried the next best thing.
I bought a wireless adapter for the other pc and voila! they are on the internet, and I am returning the router.
Westell modem + Verizon DSL w/usb = No connection to router.
Posted on Dec 29, 2009
1helpful
I cannot get my westell 6100 modem to accept a n600db belkin router. The lights on the router were bright blue, now they are a dull reddish blue that is hard to see in daylight. I cannot get on the...
Maybe it has something to do with the internet protocol of your service provider. You didn't mention anything about your internet service provider. If you have Verizon DSL and you have a PPPOE internet protocol, you need to contact the technical support team of your service provider because they need to walk you through on how to configure the westell 6100 to bridge mode. I think if you connect a pc directly to the westell 6100 and open up a browser then go to 192.168.1.1, you will be directed to the modem's GUI where you can make the necessary changes on the settings of the modem.
Switching from a verizon 6100 dsl modem to a 327w versalink
make sure that your old setup not still on go to connect to from the start and right click on the connection and see the one that you are using is present
2helpful
2answers
Verizon DSL Internet connection intermittant Westell 327
verizon dsl westell 7500 internet light goes off 2 to 3 times daily
1helpful
Blinking light on Westell 6100 DSL modem
I have a westell 6100 modem also- The light your are talking about always blinks- it blinks as long as the internet is working (it is sending and transmitting data)
2helpful
2answers
Ps3 key change timeout using westell 6100 modem on verizon
there might be a problem with the Linksys router, the Westell 6100 should be 1st set to bridge mode in order for your router to be connected to it. or there could also be a proble on the Verizon server.
1helpful
Switching DSL Modems
Your dsl line stays the same. you're only changing your dsl equipment.
if you are not able to go online using the 327w, you might need to have it configured depending on the type of connection that you have. if you are using PPPoE (which means you enter a username and password on the modem to connect to verizon) you need your 327w configured for pppoe. but if you are using DHCP connection, any modem or routers should be plug and play.
Most verizon customers from the west coast uses DHCP while those on the east coast uses PPPoE.
You can call tech support to make sure which type of connection you are using.
DSL loses signal during VOIP call.
hi,
i worked for verizon for two years and I encounter this problem many times,to tell you honestly,its not with you internet connection since if you'll notice,while you are connected to the internet and you make a call or call someone,its interrupted... Obviously,its the phone itslelf,the signal comng from the phone is different from the signal of the internet...thats the reason why you need a modem to convert the signal coming from the phone line to make it work for internet,,,what I suggest is you change the DSL plan from the Dry Loop to the regular dsl with the phone...
thanks and God Bless
I can't get DMZ on Westell F90-610015 to work.
NEED TO FIND THE DRIVER FOR WESTELL MODEL 6100F cAN YOU HELP?
6answers
Can only get dsl if i use landline
Hi, Rob just studied ur problem.Iam a tech which handles this kind of issue. I talk to verizon,at&t,bellsouth,qwest daily for such issues. Well i can suggest u onething u can get the efficient speedstream 4100 series modem which comes with a 1 yr warranty. And also checkout with verizon clearly abt ur distance from the central office.Bcos might be ur dsl circuit may be not technically feasible i:e NTF. For further clarifications plz get back to me.
Top Belkin Computers & Internet Experts
Donivan Wise
Mehandi Husain ...
Mike
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
