iRobot Roomba 580 Bagless Vacuum Logo
Duaine Jenner Posted on Dec 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My roomba 580 runs perfectly for 10 minutes then stops dead without returning to the charger and without the usual beep to notify you of an error
Avi
Level 2:
Sniper:
  • Expert 66 Answers
  • Posted on Apr 12, 2010
Avi
Expert
Level 2:
Sniper:
Answers
66
Questions
0
Helped
79290
Points
177
Seems like a battery fault.
can you start it after it stops?
how old is it?
try reset and deep charge it
hope that helps
Why roomba clean for 2 minutes then returns to dock?
I suspect the battery is about dead. It keeps coming back for more power.
Run it away from it's charger, force it to run until it dies. Put it onto it's charger and let it charge a long time (Solid green light). Then run it again till it dies and repeat. This will perhaps force the battery to develop a longer memory
Scooba beeps 4 times
  • Lift Roomba off the floor and place it in the center of the room and restart the clean cycle.
  • If Roomba did not resume cleaning, lift Roomba and turn it over.* Inspect the Side Wheels for dirt or obstructions.
  • Test the Side Wheels by pushing them in and out and making sure they rotate freely. Place Roomba in the center of the room and restart the clean cycle..
  • 1helpful
    What are these 2 blinking lights on my irobot roomba?
    "The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
    * Pulsing Amber - Charging
    * Green - Fully Charged
    * Amber - Partially Discharged
    * Red - Almost Fully Discharged
    * Flashing Red - Fully Discharged"
    At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
    GREEN = MISSION COMPLETE
    YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
    YELLOW RED POWER BUTTON = BATTERY DEPLETED (Scheduler Models)
    RED YELLOW POWER BUTTON = BATTERY DEPLETED (Discovery Models)
    number of beeps after ?uh-oh? :
    No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
    1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
    2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
    3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
    4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
    5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
    6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
    7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
    9 beeps: Sensor error Please contact iRobot Customer Care.
    10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
    place it got stuck.
    Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
    Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
    1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
    2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
    3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
    If this does not correct the problem, please call customer support at 877-855-8593
    Nov 22, 2012 • Vacuums
    2answers
    I starts and tehn stops and beeps three times. I can start it aain and it will run but then it does the same thing'
    TYhe iRobot Roomba has different model designations. Here is a webpage with a list of what the beeps mean in the 400 series. I am thinking that is what you have. 3 beeps means the dirt cup is dirty, filters are dirty, or debris in collecting and it needs to be cleaned.
    Here is the webpage: http://uksupport.irobot.com/app/answers/detail/a_id/1047/kw/iRobot%20Roomba%20Discovery%20SE%20Bagless%20Robotic%204200%20series%20Vacuum%20beeps%203%20times/related/1
    Hope this helps. If it does, I would appreciate a vote. Thanks,
    Handie Andie
    Roomba stopped after 45 minutes. does not move. manually placed on docking station...nothing
    Sounds like something's dead either with the roomba or the charging station or power supply. Does it charge up if you plug the power supply directly into the roomba, instead of into the charging station? If not, you'll probably have to return it to the place you bought it.
    1helpful
    My irobot (Roomba)is only working for 10 mins then
    It should take about 6 hrs to charge. I had the same problem and reset the charging circuit. 1) Charge it until the green light comes on. 2) Unplug and pull battery out. 3) hold down the power on button 15-30 seconds. 4.) Put the battery back in, plug in the charger (direct - not through the dock) and charge for 72 hrs. Then, run at Max clean until the "I'm dead" tune plays.
    1helpful
    2answers
    My roomba was not used for a month. Now it does
    Hello
    You can revive the dead nicd batteries in your tools.
    There is a simple guide that can fix all nicd batteries in few minutes, available here.
    Thanks
    2answers
    The Roomba goes around in circles. If it
    Are you sure it is 10 beeps ?
    look in your user's manual, the beeps code is there with some
    suggestions how to solve it
    Have fun
    Avi
    2answers
    Red sensor
    If your Roomba's red "check robot" light comes on, the Roomba should also give a hi-lo warning tone, then a number of beeps. Check the number of beeps with the chart toward the end of your manual-- it should tell you what to do.
    Roomba discovery
    Greetings doreen f,
    The roomba unit carries a one year manufacturers warranty, so you should be able to bring it into your local Best Buy™ store and have them try to repair it.
    I hope this helps!
    Dorothy
    Go Ahead, Use Us.
    Top iRobot Vacuums Experts
    Oliver Street
    NOEL
    NOEL
    Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
