Question about Sharp Office Equipment & Supplies
System error (f2-04) for model #AR 168S
System error (f2-04) for Sharp Copier, model #AR 168S
Posted by fdny158 on
Anonymous
  • 541 Answers
F2 codes all have to do with the drum. have you replced the drum lately?
Posted on Dec 30, 2009
System error H4-00 sharp AR-M150
Paper jam error how to solve that error.. please help me
Sep 22, 2011 | Sharp AR-168S Copier
System error H4 00 dont know what to do
H4 error is a temperature error in the Fuser. Usually this requires the fuser to be replaced. This is not something that should be done by a end-user, but rather by a trained technician.
Sep 12, 2011 | Sharp AR-168S Copier
How do you clear the error message on a AR-168D?
We inject the cartridge int he printer it gives the message on AR-168S
Apr 07, 2011 | Sharp AR-168D Black and White Copier
System error F2-F4
Hello sir; The error code you display on screen , the problem it caused by toner cartridge, change a right one should take care the problem.
Feb 02, 2010 | Sharp AR-168S Copier
After insalling new toner I got system error F2-04
Are you sure you removed all the packing tape and paper from the cartridge before installing it? Are you sure it is the correct one?
Aug 16, 2009 | Sharp AR-168S Copier
System error [f02-04]
I believe you asked the same question before.... Make sure the waste toner cover / plug is removed and that you shook the cartridge to loosing the toner. You may have recieved a bad or defective toner cartridge...Good Luck
Need code to reset AR 168S copier
yes i know you press c photo c photo then all light is off press up and down arrow key
Jun 11, 2009 | Sharp AR-168S All-In-One Laser Printer
System error H4-00
H4 indicates a heating problem in the fuser. The roller never reached a specific temp. Make sure the fuser is free of any left over paper pieces (maybe from a paper jam). Check to make sure its clean.
Try reseting the the error in service mode.
To enter the test command mode, press the keys as
follows one after the other :
[#] key [*] key [C] key [*] key then enter 14 and press start/copy key. this clear error counter. make sure to restart copier afterwards.
May 19, 2009 | Sharp AR-168S Copier
Sharp AR-168S
check in the exit part of the machine, front edge there is a holding pin that may not be removed. it should just unscrew to release the scaner. (it should be blue or green).
Oct 24, 2007 | Sharp AL 1631 Copier
570 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
George Mclaughlin
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
