Question about Sony SPP 111 Cordless Phone (SPP-111)
RECHARGEABLE BATTERY PACK (BP-T16,1)
HELLO, I'M FROM GREECE & MY NAME IS NICK TERMENTZOGLOU.
I HAVE A SONY CORDLESS TELEPHONE WITH ANSWERING SYSTEM (SPP-A40/A60), I'VE LOST THE RECHARGEABLE BATTERY PACK (BP-T16,1), WHERE CAN I FIND ONE OR WHAT ELSE CAN I USE IN STEAD OF THIS?
THANKS
MY e-mail: [email protected]
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Most any store that sells batteries like Walmart, Target,
Most any chain **** store. You may not find this # but there are replacements that will fit. Maybe take your handset with you.
Len
Posted on Oct 17, 2017
3 Suggested Answers
6ya staff
SOURCE:
hmerchant110
AliTech110
  • 7191 Answers
SOURCE: USER MANUAL FOR SPP-AQ600 CORDLESS TELEPHONE...
You can download the user manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Posted on May 16, 2010
  • 102366 Answers
SOURCE: Manual for an older model Sony telephone/answering machine system
http://esupport.sony.com/US/perl/model-documents.pl?mdl=SPPA400
Posted on Jul 21, 2010
Can I dissasemble a BP-210N battery pack and refill it?
You could do this absolutely, however with the cost of the batteries needed and the knowledge needed to safely solder to batteries terminals it is more cost effective and safer to purchase from Ebay.
$16.99 coming out of Gardena, Ca with free shipping BATTERY FOR ICOM BP 210 BP 222 BP 210N BP 209N BP 222N
Oct 02, 2015 | Radio Communications
The phone not working even after several hours regharging
Check rechargeable battery pack connected, if correct then batteries could need replacing!
Oct 13, 2014 | Uniden DECT 6.0 Cordless Telephone...
Looking for a part number for the internal battery
Hope this helps this should be the part# for battery pack for you label maker P# TLS2200-BP
Jun 10, 2014 | Brady TLS 2200 Label Printer
The cordless handset is not working
I suppose you put the handset back on the base unit so that they synchronise first.
Nov 29, 2013 | Sony SPP AQ600 Cordless Phone
I have an older Uniden PowerMax 5.8 and the handsets are old and one is held together with tape. The second hand set was rained on yesterday. It was sorta working but I worried i would short it out if I...
Hello, Terrie.
Sorry for the delay in responding - time zone difference.
First, let's see if we can fix your handset (from Uniden):
1. Remove the battery cover and leave it off for ventilation.
2. Remove the battery pack by disconnecting.
3. Leave the battery cover off and the battery pack disconnected for at least 3 days.
4. Once completely dry, reconnect the battery pack and the battery cover.
5. Recharge the handsset's battery pack for 20 hours in the base unit before using the phone. IMPORTANT: You must unplug the telephone line while recharging the battery pack
to avoid charge interruption.
I believe there is a way to export your phone book to another handset, but not without reviving your original phone. Unlike a cell phone, there is no memory card to remove and transfer.
Let me know what happens.
Hope this helps.
Oct 06, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
I need a replacement battery for a sony cordless phone battery no. byoog8 bp t23 dc 3.6v 600mah
pls check this link:
http://www.amazon.com/Replacement-Cordless-Phone-battery-BP-T23/dp/B000JQOYH0
original sony replacement will give you best results - but the price is higher than non branded.
regards
Feb 12, 2011 | Sony SPP-A900 Phone
How do i put the ring tone back in the handset
    Does the Phone Power Up?
  1. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  2. Does the Battery Hold a Charge?
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
  4. Listen for a Dial Tone
  5. If the GE cordless phone powers on, and beeps when you press keys, but no dial tone is heard, one of three problems is the likely culprit. The phone's batteries may have an insufficient charge to fully power the phone, a condition that can be corrected by simply placing the phone back in the charger. If the batteries are charged, but no dial tone is heard, it is also possible that another telephone in your home or office is "off hook" or in use; verify that all telephones, fax machines and modems are securely on the hook. If there is still no dial tone, your telephone service may have been disconnected or require service by your local telephone company.
  6. Listen for Static
  7. On some GE cordless phone models, particularly older models, static may be heard if the radio signal between the handset and base unit experiences interference. Common sources of interference include unshielded electronics, appliances, and radio transmitters, as well as high-tension power lines. If your phone offers an option to change channels, try several different channels to see if the static is eliminated. If static continues to exist, or if static can be heard on wired phones sharing the same line, your telephone line may require service.
  8. Verify Your Handset is Registered
  9. Some models of GE cordless phones may display a message on the display screen that the handset needs to be registered. If this message appears, move the handset close to the base unit and press the "Prog/Mute" button near the bottom of the handset. Next, press the "Pager" button on the base unit (your handset may instruct you to perform this step). Finally, press the "Prog/Mute" button on the handset one more time to complete the registration process. Your GE cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems .
  10. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  11. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  12. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears
Nov 17, 2009 | Uniden Cordless Phone
NO CALLER ID 25881EE3-A
The GE Cordless Phonemag-glass_10x10.gif brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems.
    Before You Start
  1. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  2. Phone Setup
  3. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  4. The Basics
  5. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Nov 14, 2009 | Uniden Cordless Phone
American Telecom cordless answering machine w/3 ext. #RA2184BB
You more than likely have one or both batteries DOA. Switch them out with OTC rechargeables.
Jan 23, 2009 | ATS RA2180BB Cordless Expansion Handset
Sony SPP 111 Cordless Phone (SPP-111) Logo
106 people viewed this question
Top Sony Lands Phones Experts
Marvin
Marvin
mark gardner
mark gardner
durantheman
Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
