Marantz SR-5200 Receiver Logo
Question about Marantz SR-5200 Receiver
Sr5200, when using the "tuner" mode, is stuck in the AM frequency! I've pushed every button on the front panel and the remote. How do I change to FM?
  • Anonymous Jan 04, 2010
    Thank you for the post satavlad, I had not tried that before. With great anticipation I pressed the "tuner" button twice, however nothing happened. I wonder if that part of the receiver might be broken? Everything else seems to work just fine though. Any other suggestions?
    Thank you satavlad for the input. With great anticipation, I pressed the TUNER button twice however nothing happened. I wonder if my remote or receiver are busted, although everything else seems to work fine. Any other suggestions?
Anonymous
  • 405 Answers
Push TUNER button twice, it will switch betwin AM and FM.
Posted on Dec 28, 2009
Radio tuning
PIONEER VSX-D903S - A/V Receiver
PIONEER CU-VSX079 - Remote
Here's the basics: Make sure your receiver is in the Tuner mode, by selecting Tuner on either the remote (grey button), on the receiver, or from the GUI menu. (The display will also show TUNER.) There are a couple of different ways to tune a station. One method is with the remote. Use the Band button on the remote (or via the GUI display), or the FM/AM button on the receiver, to select the frequency type. Use the Freq/Ch buttons on the remote to tune, the number buttons for presets (30 presets total. Examples: Preset 5, simply press 5; Preset 15, enter 5-5; Preset 25, enter 5-5-5). You can also use the on-screen GUI menu and the remote to tune stations, using the lower grey buttons. If you want to tune directly, via the receiver, press Select, to switch between frequency tuning and presets (displays ST CALL) mode. Use the Multi-Jog dial to make your selection in either mode. The easiest way to program a station into a preset is to use the onscreen GUI menu. [NOTE: The GUI mode (TV Monitor Video Out, composite video) is active when an amber (orange) ring glows around the Multi-Jog dial (the GUI button on the receiver will also glow simultaneously). Use the remote lower grey buttons, or use the Multi-Jog dial and Select, to move the cursor and select commands on the TV. This A/V Receiver handles composite video/S-video, and Stereo/Dolby 3-Channel/Dolby Pro-Logic audio only. (Pre-ATSC/HD video, Pre-Dolby Digital/DTS multi-channel surround audio)]
1helpful
I have a eur7711150 remote for a panasonic radio that was my dads.. i cant figure out how to change channels on the radio.. hate to sound so stupid but there doesnt seem to be a tuner or a seek button
The EUR7711150 remote works for several different Panasonic CD stereo systems. To switch between AM and FM, press the Tuner/Band button. (If you were in another mode, you'll need to press the Tuner/Band button once to get to the Tuner mode and then toggle if needed.) Then if you press Play Mode (above Repeat to the left of the number keys), you can toggle between Preset and Manual. In Preset, the rewind and fast forward buttons select between your preset stations. Alternatively, you can set the presets to numerical values and touch the appropriate number button. (Touch the >=10 button first to access Memories 10-15.) If you are on Manual, the rewind and fast forward buttons will let you move up and down between the frequencies. Pressing and holding Rewind or Fast Forward for a moment will let the radio scan to the next frequency in that direction with a signal.
The CD button enables the CD or MP3 disc player mode. AUX and Tape are for external audio devices and cassette tape mode, respectively.
These comments are based on using the remote with the Panasonic SA-PM19. Please add a comment with the specific model of your Panasonic radio if you need additional assistance.
I hope this helps.
3answers
How do I change the radio station on my pioneer vsx-d903s
Welcome to FixYa.
You need to use the remote control to access the radio station frequencies.
Follow the instructions below:
Thank you for using Fixya. Have a great day!
Jas247
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
I used to be able to change picture mode (dynamic fixed) (standard) etc.. but now stuck on standard. I have lost the picture mode option and can't get it back to the brighter richer (dynamic fixed mode). ...
Go in the tv menu,right at bat u in the Picture mode go down the menu to reset push it.The Tuner board will reset it self.It will be set on the Dynantic fixed mode.And the AV mode button on the remote should able to changes back and fourth again Dynamic fix mode,Dynamic mode,Standard mode,User mode,Game mode.Not able to changes by pushing the remote button AV mode to changes,than ur Tuner board have problems,not working properly.
We hit a button on the remote and lost the Tuner, so we can't get any channels. I think we hit the factory settings mode. What can we do to get the tuner back?
the tv is problably in video input mode-find eithor input or video on remote push it until tuner function appears -if you need more help get the model number of tv and repost it
Marantz SR5200 receiver works only with remote not manually
Check for a stuck/jammed switch, press each switch if one doesn't make a normal click sound or it doesn't move at all that's your problem.
If that's not it check the owners manual for how to reset the receiver (not all manuals will tell you how to reset it) Another way to reset it is to short the memory cap, but that is better left to a tech.
2answers
Universal remote works for basics but won't change input
Rich,
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
cheers,
mark
Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
3helpful
3answers
Marantz SR5200 - front speakers not working unless direct
If you try and unplug it at least 12 to 24 hours and it does the same thing, then its time to take it in to the shop.
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
