Toys Logo
Posted on Dec 28, 2009
My new storm tracker STX7500 weathertech does not display the outside temperature
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
330
Points
Take out the batteries in the main station for at least 5 min. Also, check the batteries on your outside station and make sure that they are new and the same brand, not rechargeables. Make sure that the outside station is reading a temperature and humidity first. Make sure that the outside gauge is close enough to your inside station. Having your inside station to near electrical or metal things or the outside station too far from the inside station is the most likely of your problems. To test this, once you've restarted your inside station, bring it close to the outside station and see if it's reading. Also, check the bottom right to see if your inside station has an antenna icon. If so, it's just updating from the radio station that updates your station often. Wait for that antenna to disappear from the bottom screen before trying to figure if your outside station is reading correctly. Finally, make sure that you have the right time zone, state, and city programmed into your inside station. If none of these work, call or e-mail the link in your book. Hope this works.
2answers
My Buick Rendezvous has the DIC. It works fine but the temperature is always 0 celcius (says 0C). Got 2 new outside air sensors from junkyard and no change. Should i check something else like voltage?
It should be possible to test the sensors with an ohmmeter (I think) as they will likely be temperature sensitive resistors or thermistors.
Testing the voltage was the thing to do in the old days of analogue and direct current systems but I think you will find the electronics on your car is digitally based and difficult or impossible to test with an ordinary meter. An oscilloscope will probably be needed...
1helpful
Where is the ambient temperature sensor located ?
images for 2008 Chevrolet HHR LT Where is the .
Outside Temperature Sensor - Chevy HHR Network
www.chevyhhr.net/forums/...hhr-4/outside-temperature-sensor-30594/
Jul 9, 2010 - I had the outside temp sensor go on my 99 Buick. I don't know where it islocated on the HHR, but it was just a plug in sensor. Take out the old, stick in the new.... 2008 HHR LS 2.2 L Auto Built: 12-19-2007. Bought: 4-26-2009 Location of the ambient engine temperature sensor.... Help ...
Mar 26, 2013
Engine Temperature Sensor
Oct 6, 2011
Outside Temp Display
Dec 19, 2008
Outside air temperature problem
Oct 30, 2007
More results from www.chevyhhr.net
1helpful
Outside temperature sensor
The outside air temperature indicator's displayed temperature can be recalibrated. Press and hold the reset select button for 10 seconds . While you continue to hold the button, the display will scroll through temperature settings from +3 to -3. When the desired correction value appears on the display, release the button, and the recalibrated outside air temperature will be displayed. Each time a desired correction value is entered, it replaces the previous value. Give that a try mmkayyy:)
Outside temperature display (next to a/c display?)
The ambient air temperature sensor at the fron of the car has gone bad, a new one can be obtained from any GM dealer.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Outside unit not registering temp and humidity to base unit
Uniden EWCI936
To get the outside temperature working again, open the outdoor sensor box carefully loosening the one screw with a screwdriver, insert 3 brand new AA batteries, check phone for outside temperature. If not showing on the phone display, try changing the 'channel' setting, just above the batteries. Be careful not to break the tiny switch. Gently use a smaller flathead screwdriver, if needed. There are 3 settings. Mine worked fine on the first setting. If it is showing on the phone set screens, then, carefully screw the lid back on to the sensor box, and re-insert into the sensor wall holder. I keep mine in a plastic bag on a shelf outside, away from sun, so I can get a true reading day or night. It is always a bit warmer in the sunlight than the true outdoor air temperature. Enjoy
Where to put outside remote
If you have storm windows, put it between the window and the storm window.
Or try just below the overhang of your house.
Top Discovery Channel Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Discovery Channel Toy Expert? Answer questions, earn points and help others
