Question about Canon PowerShot A710 IS Digital Camera
PORTRAIT SETTING ON Canon Powershot A710 IS GIVES EXACTLY SAME PHOTO AS ON AUTOMATIC. NEED I ACTIVATE SOMETHING ELSE TO GET A BLURRED BACKGROUND?
Posted by trevor_cates on
CameraR
  • Canon Master
  • 4,738 Answers
Portrait provides extra sharp focus on the subject. It also opens the aperture some, and may in SOME cases give you a blurred backbround depending on the distance of the subject and background to the camera.
If outdoors, consider setting the camera to manual flash so that it will lighten the subject. If indoors, consider turning off the flash. You may need to provide better external lighting on the subject, or use a tripod and ask the subject to hold still during the picture.
Try increasing the zoom (best is to set it to maximum), and then adjust your distance from the subject to get as close as possible. Note that you still might be standing relatively far away because of the zoom.
Another way to experiment further with focus and blurred backgrounds is to use aperture priority (Av) mode on your dial. Use the right/left button to set the lowest "f-number" on your screen. The lower the number, the greater the aperture. All other functions of your camera will automatically compensate. Again, use max zoom in taking closeups with low "f-numbers". Also experiment with the manual focus to pay particular attention to achieving sharp focus on your subjects eyes.
You have a very capable camera. It can do what you're thinking of. You just need to practice with it. It's digital, experiment with the above techniques. Throw away the bad pics and keep the good, noting which technique worked best for the lighting and situation.
Posted on Dec 28, 2009
I couldn't seem to blur my portrait backgrounds with the canon powershot a1200. can you help me with step by step instructions? does the a1200 have an AV mode at all? thanks
You're trying for what's called a narrow depth-of-field (DoF).
DoF is controlled by three factors: the aperture of the lens, distance to the subject, and the focal length of the lens. This has nothing to do with any particular design, it's simply physics.
The wider the aperture (smaller the f/number), the narrower the DoF. The A1200 does not have an Av mode which would let you control the aperture directly. However, it does have a Portrait mode, which is supposed to give you a wider aperture.
The closer you are to the subject, the narrower the DoF. This suggests that you get as close to the subject as practicable. However, in general you don't want to get too close for portraits as this tends to exaggerate certain facial features, like making noses look bigger.
The longer the focal length of the lens, the narrower the DoF. This suggests that you back away and zoom in. Yes, this conflicts with the previous paragraph.
Unfortunately, it's the actual focal length of the lens that matters here, not the "35mm equivalent" often quoted in the spces. The lens on the A1200 zooms from 5mm to 20mm. Landscape photographers like to use 24mm lenses on their 35mm cameras because that gives them practically infinite depth-of-field, from the flower in the foreground to the mountains in the background. The lens on your camera is shorter than that, so you're going to have a hard time blurring portrait backgrounds.
The best I can recommend is to put the camera into Portrait mode, put as much distance as possible between the subject and the background, get as close to the subject as possible, and zoom in to the longest focal length you have (remembering that the last two are in conflict).
Jun 14, 2011 | Canon A1200 Digital Camera
I'm getting blurred images. what will be the
Blur images can caused dirty lenses please clean the lenses if the problem persist then take to any service center and do cleaning of the internal parts as sometimes due to moisture this type of problems are created.
Feb 16, 2010 | Canon PowerShot A710 IS Digital Camera
How to overcome Grainy photos on some in door shots with my Canon A710
The reason for this is that the auto scene function chooses which ISO (light sensitivity) is needed to have a fast enough shutter speed to capture a still image (instead of a ghosted image). There is no way to change this. You can switch modes to P and specify the ISO you want to use (100-200 will give you a clear, non-grainy image, 400+ will be grainy). To capture a still image in low light with a low ISO, you need to use a tripod. Hope this helps.
Sep 22, 2008 | Canon PowerShot A710 IS Digital Camera
Image Stablization not functioning
Image stabilization cannot correct for movement of the subject (fan). Image stabilization only corrects for movement of the camera/photographer. If you take a picture of the ceiling fan with the flash turned on, or set the ISO to a higher number, you will see that the fan is less blurred because you have increased the shutter speed.
May 01, 2008 | Canon PowerShot A710 IS Digital Camera
Canon Powershot S5IS Aperture
Hey Kate
I have owned a Canon Powershot S5 since launch last year and I take a lot of photos with blurred background. I select AV on the dial (Aperture priority) and set aperture to between 2.7 and about 4.0 max, depending on how much depth of field I want and what my subject is.
This setting blurs the background beautifully.. Just remember that an aperture of 2.7 will give you a very shallow depth-of-field, so if focus on face is important, make sure you have face recognition set to ON.
I hope this helps
Apr 04, 2008 | Canon PowerShot S5 IS Digital Camera
Exposure control options
The following exposure options are available: P (Program auto), A (Aperture priority), S (Shutter priority), and M (Manual). There are five scene programs modes available in which the camera will choose the optimal settings for the picture: - Landscape + Portrait: Suitable for taking photos of both you subject and background. The picture is taken with the background as well as the subject in the foreground in focus. - Landscape: Suitable for taking photos of landscapes and other outdoor scenes. Both the foreground and the background are in focus. Since blues and greens are reproduced vividly in this mode, the landscape mode is excellent for shooting natural scenery. - Portrait: Suitable for shooting a portrait-style image of a person. This mode features an in-focus subject against a blurred background. - Sports: Suitable for capturing fast-moving action such as sports scene or moving vehicles without blurring. - Night scene: Suitable for taking night scene photos with a slower shutter speed.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Shooting modes
The shooting modes are as follows: PROGRAM (P)/AUTO Modes. Used for general photography. The camera automatically makes the settings for natural color balance. In PROGRAM AUTO (P) the brightness (exposure compensation) can be adjusted. Portrait. Suitable for taking a portrait-style photo of a person. The camera automatically sets the optimal shooting settings to produce natural skin tones. Landscape + Portrait. Suitable for taking photos of both your subject and the landscape. This setting allows both the foreground subject and background landscape to be in focus. Landscape. Suitable for taking photos of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting settings to produce vivid blues and greens. Night and Portrait. Suitable for taking photos of your subject in the evening or at night. Since the shutter speed is slow, it is advised that you use a tripod to support the camera in this mode to help avoid blur from camera shake. Night Scene. Suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting settings. If you use the flash, you can take pictures of both foreground subjects and the background. It is advised that you use a tripod to support the camera in this mode to help avoid blur from camera shake. Sports. Suitable for capturing fast moving action without blurring. Even a fast moving object will appear to be stationary. Self Portrait. Enables you to take a picture of yourself while holding the camera. Point the lens toward yourself and the focus will be locked on you. The camera automatically sets the optimal shooting settings. The zoom is fixed in the wide position and cannot be changed. Movie Mode. Enables you to take a QuickTime movie.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Shooting modes
The Shooting modes are as follows: PROGRAM (P)/AUTO Modes Used for general photography. The camera automatically makes the settings for natural color balance. In PROGRAM (P) the brightness (exposure compensation) can be adjusted. In AUTO mode you cannot use exposure compensation or panorama features. Portrait Suitable for taking a portrait-style shot of a person. The camera automatically sets the optimal shooting conditions. Sports Suitable for capturing fast moving action without blurring. Even a fast moving object will appear to be stationary. Landscape Suitable for taking photos of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Night scene Suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both the subject and the background. Nightscene + Portrait Suitable for taking photos of your subject in the evening or at night. This setting employs a slow shutter speed, the camera should be stabilized to avoid camera shake resulting in a blurred picture. Landscape + Portrait Suitable for taking photos of both your subject and the landscape. This setting allows for both the foreground subject and background landscape to be in focus. The camera automatically sets the optimal shooting conditions. Self Portrait Enables you to take a picture of yourself while holding the camera. Point the lens towards yourself and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is locked to wide-angle and cannot be changed. Indoor Optimum settings for taking pictures of family gatherings and groups of friends. This mode reproduces the background clearly capturing the atmosphere. Beach Suitable for taking photos at the beach under a bright blue sky. Colors of the sky, the beach and people are reproduced vividly. Snow Optimun settings for taking pictures where backgrounds are snow fields. Settings are similar to Beach settings and colors of the sky, the greenery and people are reproduced vividly. Fireworks Optimum settings for capturing fireworks in the night sky. Since this setting employs a slow shutter speed , the camera should be stabilized to avoid camera shake resulting in a blurred picture. Sunset Optimum settings for capturing pictures of the setting sun. This mode reproduces reds and yellows vibrantly. Again, this setting employs a slow shutter speed , the camera should be stabilized to avoid camera shake resulting in a blurred picture.
Sep 01, 2005 | Olympus D-595 Zoom Digital Camera
Shooting modes
The Shooting modes are as follows: PROGRAM (P)/AUTO Modes Used for general photography. The camera automatically makes the settings for natural color balance. In PROGRAM (P) the brightness (exposure compensation) can be adjusted. In AUTO mode you cannot use exposure compensation or panorama features. Portrait Suitable for taking a portrait-style shot of a person. The camera automatically sets the optimal shooting conditions. Sports Suitable for capturing fast moving action without blurring. Even a fast moving object will appear to be stationary. Landscape Suitable for taking photos of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Night scene Suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both the subject and the background. Nightscene + Portrait Suitable for taking photos of your subject in the evening or at night. This setting employs a slow shutter speed, the camera should be stabilized to avoid camera shake resulting in a blurred picture. Landscape + Portrait Suitable for taking photos of both your subject and the landscape This setting allows for both the foreground subject and background landscape to be in focus. The camera automatically sets the optimal shooting conditions. Self Portrait Enables you to take a picture of yourself while holding the camera. Point the lens towards yourself and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is locked to wide-angle and cannot be changed. Indoor Optimum settings for taking pictures of family gatherings and groups of friends. This mode reproduces the background clearly capturing the atmosphere. Beach Suitable for taking photos at the beach under a bright blue sky. Colors of the sky, the beach and people are reproduced vividly. Snow Optimun settings for taking pictures where backgrounds are snow fields. Settings are similar to Beach settings and colors of the sky, the greenery and people are reproduced vividly. Fireworks Optimum settings for capturing fireworks in the night sky. Since this setting employs a slow shutter speed , the camera should be stabilized to avoid camera shake resulting in a blurred picture. Sunset Optimum settings for capturing pictures of the setting sun. This mode reproduces reds and yellows vibrantly. Again, this setting employs a slow shutter speed, the camera should be stabilized to avoid camera shake resulting in a blurred picture.
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
Canon PowerShot A710 IS Digital Camera Logo
210 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
halotheracer
halotheracer
Are you a Canon Camera Expert? Answer questions, earn points and help others
