Question about SanDisk Sansa View 8GB MP3 Player - Black
Ive been trying to add photos to my SanDisk Sansa
I've been trying to add photos to my SanDisk Sansa View and they dont show up. I've been using the sansa media converter to do it and it say's that the converting went by without a hitch but my pictures still dont show up on my sansa. help?
Posted by ragdoll231 on
Anonymous
    Guru:
  • 82 Answers
U may check it carefully and follow this guide:
The Sansa Media Converter (SMC) software is required to convert and transfer videos and photos (pictures) to your Sansa player as well as the memory card in your Sansa player.
NOTE: Only the Sansa e200v2, Fuze, and View allow viewing of video files from the memory card.
STEP 1 - Download and install Sansa Media Converter
The Sansa Media Converter application is available via the Sansa Firmware Updater.
STEP 2 - Convert and transfer your video or image files
NOTE: To see a list of supported image/video file formats, see Sansa Media Converter does not convert a file
1. Run the Sansa Media Converter.
2. Connect the Sansa player to the PC.
3. If a Portable Device windows appears, select Sansa Media Converter using Sansa Media Converter.
4. The Sansa player should appear on the left pane of the Sansa Media Converter console.ive been trying to add photos to my SanDisk Sansa - id101-2.gifg src="/uploads/images/id101-2.gif" alt="id101-2.gif" class="h_mi" />
5. Click Add Media to add vive been trying to add photos to my SanDisk Sansa - id101-3.gifto files to be converted and transferred.
(In the sample below we imported an image and a video file)
id101-6.gifMy Album by default. To place them in a different folder, select My Album then type in a new name.
7. Depending on what Sansa player that's plugged in or if ive been trying to add photos to my SanDisk Sansa - id101-5.gifs present in the Sansa player, click on the Sansa player or the micrive been trying to add photos to my SanDisk Sansa - id101-9.gifn the left pane to select where to transfer the converted files. (in the sample below, we selected the microSD card)
8. Click Convert to covert the files.
9. Once the files are converted it's automatically transferred to the device or microSD.
10. Click OK when finished.
u can try doremisoft sansa video converter for mac that not only add photos, but also take images from your favorite videos, which easy to use and just a few clicks.
By the way, u can try doremisoft sansa video converter that not only add photos, but also take images from your favorite videos, whick easy to use in just a few clicks and additional amazing functions.
free download Doremisoft sansa video converter
Posted on Mar 02, 2010
My sansa e280 doesnt show the video files
You need to use the supplied Sansa Media Converter program to convert your videos (and photos) to a format the Sansa can handle. If you've misplaced the SMC, you can download it here.
Oct 14, 2011 | SanDisk Sansa E280 MP3 Player
When i try to add a videos it tells that there is unsupported media format how can i fix it??
You need to use the supplied Sansa Media Converter program to convert videos (and photos) to a format the Sansa can handle. If you've misplaced the SMC, you can download the Windows version from http://www.megaupload.com/?d=3IPZO6Q0
May 19, 2011 | SanDisk Sansa Fuze MP3 Player
I cant seem to add photos on sandisk sansa do you kkow how to do
You need to download and install the Sansa Media Converter
http://kb.sandisk.com/app/answers/detail/a_id/4431/
And this article shows you how to use it to add videos or photos to your player.
http://kb.sandisk.com/app/answers/detail/a_id/564/
It's a little complicated compared to more modern players.
Apr 21, 2011 | SanDisk Sansa Clip MP3 Player
Need users manual and software for sandisk sansa view
Sansa View manual and the software that's needed to use this player is free and online available for download.
All support for the Sansa View:
http://kb.sandisk.com/app/answers/detail/a_id/3396/session/L3NpZC9XNkJKdVhVag%3D%3D/sno/0
Sansa Updater can be used to get directly to manual and software Sansa Media Converter. See next link:
I'd appreciate your answer if this was helpful.
Need more help ? Just add a comment in this thread.
Feb 19, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
Problem with viewing pictures and videos
Use Sansa Media Converter for putting Videos and Photos in the appropriate format. See next page for the file formats that SMC is able to convert and further requirements:
http://kb.sandisk.com/app/answers/detail/a_id/32/related/1/kw/converter/r_id/101834
Download Sansa Media Converter [size 101 MB]:
http://mp3support.sandisk.com/sansa/SMC/
Manual for the Sansa View:
http://mp3support.sandisk.com/sansa/UserManual/VIEW/View_UM_English.pdf
Sep 27, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Sansa View
Try Going to More\System Settings\Display\ Switch it between LCD and TV NTSC\PAL
experiment a bit.
Aug 10, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Cant download anything hpdv6000 to my sandisk sansa view
Install Media converter, then connect sansa. Then, it should appear in My Computer as Sansa View. You can add it there or use the converter software.
Dont know how to put pictures in my mp3
To transfer photos and video to your Sansa e250:
1. Open Sansa Media Converter on your PC
2. Connect Sansa e250 to the computer.
The detected Sansa e250 will list the available space and total space on the
device. If more than one device is inserted, only the first device will be
supported.
3. Add the media files to be converted
4. The Sansa Media Converter will place all files in MyAlbum unless you
type in a new Album Name at the bottom of the screen. Use this option
to organize your files and slide shows.
5. Press to start the conversion process. A status box will appear
showing which file(s) are being converted.
6. Photos and Video can not be transferred to the microSD card.
7. Do not move your photo or video files from the location the Sansa
Media Converter places them.
8. See Safely removing your Sansa from the Computer instructions
below.
Also you can take a look at the manual on page 16..it will give you a visual Image..
http://www.woot.com/files/sansae200manual.pdf
If you need further assistance you can contact sandisk or myself
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Mar 31, 2008 | SanDisk Sansa e250 MP3 Player
When i connect to the computer, i can add songs, but the songs on it dont show up
I don't know if you've inadvertently deleted the music folder, but that's what I did, when I deleted all the folders by mistake, thank heavens for in-store warrenty, they replaced it with another one. What I noticed on my replacement is synchronizing with media player doesn't work, it creates ghost folders and thinks music is there when it isn't, I don't understand it. Solution: open two windows for my music and sansa e280 music, then just drag and drop the folders; what I noticed is that in my music the folders are named by artist, and I prefer to see them by album, but when I view them in the player, I see the albums with the tracks in the right order.
Aug 17, 2007 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa View 8GB MP3 Player - Black Logo
Top SanDisk Audio Players & Recorders Experts
Jean Sintulaire
Daniel Dollive
Daniel Dollive
aliasger yq
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
