Question about Mitsubishi WS-65869 65" Rear Projection Television
Picture is completely out of alignment, went to do
I have a Mitsubishi WS-65869 rear projection TV. Turned it off evrything was good, turned it on 2 hours later and the Picture is completely out of alignment, went to do a convergence and the green lines are way out of alignment, and the blue and red can not be aligned with the green, what does this mean?
Posted by cranappr on
Anonymous
    New Friend:
I need part
Posted on Jan 26, 2010
Arnel
    Sergeant:
  • 184 Answers
It means the convergence IC gave up already ang needs a replacement. And also check the 5A picofuse in the power supply.
Posted on Dec 28, 2009
Video games projection on a Mitsubishi WS-65869
1,2 error code means NO ERROR FOUND. The set is older and may not be compatible with this set---what type of connection is being used and to which rear input?
Dec 16, 2012 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869 65" blue color problem
Yes, you need to replace the convergence output amplifier IC's. They can be ordered on line. After removing the back you must remove the circuit board which houses the amps. Then desolder them and install the replacemnts. If you are extremely lucky there won't be any re-alignment issues with the new amps. Then you should be good to go.
May 03, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Color is going weird
Chroma IC is to blame, but before you go replacing it, be sure that the power supply voltages are correct....accordianman
Jun 05, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Help with my big screen mitsubishi ws65869 tv
my screen is a right blue with no picture although I have sound it reads "tuner out"
Mar 27, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869
This set will require that the power supply voltage problem be fixed...accordianman
Jan 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi ws 65869 green led turns on for 2 sec then turns off
Your problem is not shown on schematic, C9A60 (470 pf @ 1000 v) capacitor and check and see if F9A04 & 05 are open. If so then its off to a whole different area. Do you have an email to send Sch.?
Jan 15, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Blinking green light stays on and TV won't turn on.
Check for open pico fuse in power supply caused by bad convergence I.C.Get pro help-you have a good set to save.Remember--practice visual acuity technique!And,above all else,do no harm!!
Aug 26, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869 65 in. Power Light
They are little green soldered in fuses located on the center board (the one with the STK's on it) toward the rear of the set near the large transformer.
Aug 24, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitshibishi 65 " HDTV
Check 5A micro fuses F9A04 and F9A05 - If one or both are open,change the single convergence IC part# STK393-110.
Aug 22, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
339 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
