Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
Posted on Dec 28, 2009
I have a magnavox mwd2205 dvd/vcr combo with no remote. I've tried programming it to my Charter cable remote and to a GE universal remote, but can't get it to do anything but turn the machine on and off. Is there a way to get it programmed so I can activate the dvd then chose special features , or do I need to get a remote especially made for this dvd/vcr?
Anonymous
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Feb 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
6
Questions
0
Helped
6224
Points
11
This DVD/VCR isn't compatible with the GE Universal remote. Sorry.
I would recommend contacting Magnavox (actually FUNAI CORP.) at www. magnavox.com, and seeing if they would be willing to send you a remote that was compatible with your player. There was another Magnavox player remote that also worked with Magnavox MWD2205. So it's possible that a number of remotes would work for you. Good luck! :)
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 26, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
3432
Points
RCA universal remote code 20000 worked for me for mwd2205. Turn on combo unit. Press and hold DVD/VCR button on remote, enter 20000, press remote power button and Combo unit should turn off.
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 28, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3726
Points
9
Ou need to get a new xbox old man
2answers
I have a Magnavox clo358 universal remote what are the codes for my Magnavox DVD VCR combo
To program your Magnavox DVD VCR combo using the Magnavox CLO358 universal remote, you can try the following codes:
0503
0675
1153
1203
1321
Here's how you can program the remote:
Turn on your Magnavox DVD VCR combo manually.
Press and hold the "Code Search" button on the remote until the indicator light turns on.
Release the "Code Search" button.
Press and release the mode button for the device you want to program (in this case, the DVD VCR combo). The indicator light should remain on.
Enter one of the codes listed above using the numeric keypad on the remote. The indicator light should turn off after entering the code.
Aim the remote at the DVD VCR combo and press the "Power" button. If the device turns off, the code is correct. If not, repeat steps 4 to 6 with the next code on the list.
If none of the codes work, or if you have any other issues, it's recommended to consult the user manual of your Magnavox CLO358 universal remote for additional instructions and a complete list of codes.
3answers
I have two RCA remotes. 1st RCU 310 5538P. 2nd RCU 400 2420BB.
Remote Control Support - RCA ' Made for Moments
www.rca.com/support-remotes
RCARemote Control Support. Select your Type of Remote. Remote Code Finder ...RemoteProgramming. Cable/Satellite Receiver Codes. Select Your Provider.
RCA Universal Remote Control- Target Programming ...
www.thompsontv.com/rcarc.html
RCA Universal Remote Control-Programming Codes. ... Universal Remote. The remotemay already be set up to operate your brand of TV, VCR, or Cable Box.
Program an RCA Universal Remote Without a "Code Search ...
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a ...
1helpful
2answers
Need code for magnavox tv urc-4021boo
Hi, the codes you have requested;
Magnavox - 0054, 0706, 0030, 1454, 1254
Instructions to program code:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if applicable, insert media (e.g., cassette or disc). NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program before starting step 2.
2. On the remote control,press a device key once (i.e., VCR/PVR, DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press VCR/PVR once.After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions. NOTE: To program control of a DVD Player,DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions. NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER once.The device should turn off. If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works.
2helpful
I have a Magnavox DVD/VCR combo that I have lost the remote to. I have bought universal remote after universal remote trying to get one that will work the DVD player or at least will setup the date and...
Universal remote does not work with Magnavox combo of dvd vcr, because no dubbing button. But magnavox has many remotes that will NB884, NB559, NB677.NB627 which also works on Sharp dvd vcr combo.
1helpful
2answers
Remote Code
Sorry but a code you want doesn't exist.
You have to have a specific remote from Magnavox or a remote that falls roughly in this line of models. The best you can get out of universal is the On/Off commands.
2helpful
MWD2205 remote stopped working for DVD functions
not sure but it sounds like you need to push the dvd button itself before dvd functions will work-it's to the left of the pause button. same thing happened to me and when i try that it works. remote seems to default to vcr i guess ....
2helpful
Need a code for a VCR/DVD player for my universal remote
Magnavox VCR. The Phillips universal remote lists the following codes:0330, 0430, 0534, 0324, 0224, 0124, 0247, 0230, 0125, 0093, 0598, 0830. Doesn't seem they have much control of which code gets used on which model. Start in the middle and work both ways to the ends. Make sure to post back which one you find that works.
Doesn't work with universal remote
I have the same problem i have a magnavox tv/dvd/vcr and none of the codes work can you help me out
2helpful
Jumbo universal remote
I found that on the back of the 2205 it said that the unit was made by Funai. I looked in the Innovage book and found that the codes for Funai DVD are 231 and 233. 233 worked on mine. Good luck.
31helpful
6answers
Remote control code for magnavox dvd/vcr combo
I need codes for my Universal Philips Magnavox remote for a Sanyodvd vcr combo ?
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
