Question about Toshiba 32AF41 32" TV
After being moved, tv has no color - Toshiba 32AF41 32" TV
Posted by davesaxsay on
Anonymous
    New Friend:
  • 139 Answers
PROBABLY LOOSE CONNECTIONS FROM THE MOVE. THERE ARE MANY REASONS THESE NTSC TV'S LOOSE COLOR
Posted on Dec 28, 2009
We moved our tv upstairs, we have a nice picture and sound but no color!
check for a loose connectors and fixed it to the pin terminal .
Oct 27, 2012 | Televison & Video
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
Feb 04, 2011 | Televison & Video
Blue gun adjustment does not move blue line in menu convergence function. Any way to adjust or fix?
No.Fix.Tv have dead parts on the tv convergence board.Tv colors lines R,G,B mis alignment,can't move any colors lines.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead on the tv convergence board.These parts,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Toshiba 61H70 61" Rear Projection...
Color wont move off of mute to align
maybe the degausing coil is defective or your tv is de magnetise or the color control is defective. if no just consult your problem to APEX service center near you
Jun 19, 2010 | Apex Digital GB4308 43" Rear Projection...
Colors are distorted on the sides. Help?!?! The TV has sat next to some speakers and has made the sides of the TV colors get all distorted (one side green and one side purple when the screen is originally...
all colored tv has built in demagnetizer and activates everytime the tv is power on.but there are instances that discoloration of screen due to magnettic effect cannot be remove by built in demagnitizer.you can buy a separate demagnitizer for tv....to use it you need to switch on the tv .plug in the demagnitizer to ac outlet point the demagnitizer in center of the screen/front press the butoon of the demagnitizer ad move it sideways and circles as if your wiping the colors repeat it untill the color is clear.
Good luck hope this could help you..
your rate is important to me..tnx...
Dec 30, 2009 | Philips Magnavox TP3285C 32" TV
My tv experienced a sudden color shift with the blue moving to the left
Blue color moved to left because of failure of convergence out IC in TV
that need to be replaced. Call local TV repair shop to fix it.
Jul 13, 2009 | Sony KP-57WS500 57" Rear Projection...
Moved tv to clean table and now all color is purple
try thumping the bottom or back cover sounds like a dry joint or bad conection good luck farr64
Apr 30, 2009 | Televison & Video
TV green screen after moving satellite receiver
a satellite receiver has its own coloring components inside it, if mixtures are not mixing properly. try that satellite receiver with differant tv. some with the tv,
Mar 27, 2009 | DISH Network 811 HD DTV Receiver
I do not have a color picture
If you had a color picture before moving the TV, then you should check the inputs. Make sure all the cabling is properly and securely attached.
If this does not help, please provide more information, such as a description of the TV, indicate whether the TV had a color picture immediately before moving it, and whether you have reason to think that there is a mode for black&white.
Nov 30, 2008 | Televison & Video
Color
replace the converge ic's
Jun 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba 32AF41 32" TV Logo
53 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
