Question about Delta Faucet 470-DST Signature Diamond Pull-Out Spray Kitchen Faucet - Blac
Delta faucet 470-ss-dst is leaking from the spout. steady stream not just drips.
Posted by cheryldlogan on
honestabe
    New Friend:
  • 18 Answers
Easy fix, shut-off water at under-counter angle valves and water meter, pop-out the blue and red insert located on the front of the handle of the faucet, turn faucet on to relieve pressure, loosen allen screw under red and blue insert, pull handle up, remove nut under handle, remove plastic insert gasket and stem under the nut, notice two rubber gaskets.... remove them and the springs behind them and replace, when putting the insides of the faucet back in pay close attention to the notches and grooves,,,, the parts only go back one way....
Posted on Dec 29, 2009
Anonymous
    New Friend:
It also may be noted that in some states such as Texas, the water is considered "hard" and tends to leave a lot of calcium deposits and buildup which affect the ability of the little black gaskets to seal. Before anyone plainly changes the gaskets, pay attention to any possible buildup that would impinge upon the ability of the gasket to seal. If you do have buildup, just use some Limeaway or Kaboom and get rid of it before you replace the gaskets and springs. You may want to try and just clean away the deposits first and then reassemble before heading to Home Depot for the parts..? Anyway the advice above is very helpful. If you don't know what parts the advice is referring to, just head on over to DeltaFaucet.com and get your model and drawings. They're very simple to understand.
Posted on Jan 23, 2010
Taras Chichak
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Good news, the repair is very simple and cheap, just a trip to Home Depot. The only part that can cause this faucet to drip is a sealed cartridge that has a life time warranty. Disassemble the faucet and take the cartridge to Home depot, they will replace for free no questions asked. Worked wonderfully for me.
Posted on Jan 08, 2013
I"m removing and replacing a
Since you are replacing the Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray faucet, bend the water supply lines out of the way, and then use a standard basin wrench to remove the nut.
Jan 25, 2011 | Delta Faucet Delta 470-BL-DST Signature...
Delta Faucet Company 467-SSSD-DST Palo Diamond Seal Technology Pull-out Kitchen Faucet, Stainless, 3 years old and is beginning to drip unless we position the handle just right. Is there a washer? I've...
I hope this will help please go to this web site for a downloadable parts link. If it is leaking from the spout replace the seats and springs to correct the problem. Turn water off and remove handle with a 1/8" allen wrench and remove retaining collar to access the ball assembly to remove the seats and springs.
The parts page on this link will give you a break down and hope this will help.
http://www.deltafaucet.com/kitchen/details/467-SSSD-DST.html
Dec 30, 2010 | Delta Faucet Delta 467-SSSD-DST Palo...
After replacing seats & springs, no water will come out of spout. Sprayer works fine. Put old seats & springs back in & same problem.
need to put in little round ball back.. the right way..make sure ball is in right before putting hold down holding piece w notch in it
Nov 21, 2010 | Delta Faucet Delta 470-BL-DST Signature...
Facet still leaking after replacing the RP4993G part.
Make sure the area below where you replaced that part is free of scale and is not damaged in any way. Scuffs, scale and dirt will caused your leaking.
Sep 13, 2010 | Delta Faucet Delta 470-BL-DST Signature...
Need "0" rings for delta 470 faucet
You should be able to find them at lowes or any other hardware store.
Jan 27, 2010 | Delta Faucet Delta 470-BL-DST Signature...
Need to take the hose assembly out of delta 470 faucet
you need to disconnect from under the faucet and then pull it all the way out just like if you were pulling it out to use the spray. There may be a big weight on the hose to help it back into the spout when placing the head back....you will also have to take that off to pull it through.
Oct 04, 2009 | Delta Faucet 470-DST Signature Diamond...
DANCO brand generic hose not connecting to supply
You have to buy a Genuine Delta Part because Delta uses a proprietary quck connect fitting at the end of the hose.
May 28, 2009 | Delta Faucet 470-DST Signature Diamond...
Single handel kitchen faucet: Over time the
shut-off the water, pull the handle and the spout. change the 2 "O"ring and make sure the spout body has no dirt in them. apply some the plumbing grease bewteen the spout body. put everything back.
Apr 22, 2009 | Delta Faucet Delta 470-BL-DST Signature...
Replace the seal on the 470 DST single handle pull out faucet
Turn the water off at the faucet, remove the handle and the retaining nut that is apart of the trim. You will see where you can use a wrench to remove it. The ball assembly will come right out and you can replace the washers right below it. Put it back together and if needed, tighten the tension ring that is on the retaining nut (usually grey or white in color) so it won't leak water around the ball stem. Good luck.
Apr 02, 2009 | Delta Faucet Delta 470-BL-DST Signature...
Delta Faucet 470-DST Signature Diamond Pull-Out Spray Kitchen Faucet - Blac Logo
3,628 people viewed this question
Top Delta Faucet Plumbing Experts
Muntejaya Ginting
Muntejaya Ginting
Bill Johnson
Marvin
Marvin
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
