Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
Posted on Dec 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to locate my security key to connected to my wireless internet, how do I do this?
Anonymous
Level 2:
  • Expert 298 Answers
  • Posted on Dec 28, 2009
Anonymous
Expert
Level 2:
Answers
298
Questions
0
Helped
223281
Points
828
Security key in case you didn't know is your password for the wireless network. And you can find this by logging on to the web user interface of the router and check it from there. What is the brand and model of your router?
I have wireless internet how do I get a ip address connect my ps3
The IP address is provided by the wireless router when you perform the connection process. You will need to locate your wireless network on the PS3, select it, and when prompted for the security key/code, enter it to gain a connection. Once the connection is established, the PS3 will have an IP address.
I purchased an Asus EeePad Tablet. How can I connect to the Internet and google? The tablet has WiFi.
You need to connect to your wireless router that is connected to the Internet via a cable or DSL modem OR to a Internet cafe WiFi hot spot at a location such as McDonalds, Star Bucks.
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
4answers
Trying to connect wii to internet....its asking me for a security key
Maybe you set the WEP security in you WiFi Router, if you hace access to console http://192.168.0.1 you can look at it.
Hope will help
Regards,
I cant get a internet on my console wii
You have 2 wireless options. Either you use the built in wi-fi of the Wii by selecting the internet menu option, locating your wireless ID and entering your Security Key. Or use a USB wireless device to receive your wireless connection. If you need more help, give more details!
How do i connect to internet with ps3, wireless, what is a wpa key?
WPA stands for Wi-Fi protected access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over WEP (Wired Equivalent Privacy) standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
While connecting to your home network, you are often asked to insert a WPA key. This WPA key is either located in the modem or in the router you are using. In order to find your computer's WPA key, follow the steps given below:
You can correct this problem by entering the WPA Key into your PSP's Network Settings. But before you do that you need to know what your WPA Key is...
Step 1: First of all, you need to launch an internet browser. Press "Windows + R" keys to open the "Run" prompt and type "iexplore" without quotes to open Internet Explorer. You can also type "firefox" to open Mozilla Firefox. On the address bar at the top, type http://192.168.1.1 (Belkin routers use 192.168.2.1 as the default IP) and press "Enter" key.
This address belongs to your wireless modem or wireless router to which you are connected.
Step 2: A window asking for username and password will appear. In the username field, type "admin" without quotes and in the password field, either type "password" without quotes or leave the password field blank. Press "Enter" key to continue.
If password is correct, you will be redirected to the modem/router's "Settings" page, otherwise, you will have to reset the modem/router. Check beneath the modem/router or check the manual for correct password.
To reset a Linksys modem/router or Belkin one, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
Repeat the step 2, in order to gain access to "Settings" page.
Step 3: On the modem/router's "Settings" page, find "Wireless" option. Click the "Wireless" link to populate the wireless settings. Now, locate and click the "Security" or "Advanced Security" option.
On the security page, you will find "Network Authentication". Different options available under the Network Authentication menu are open, shared, WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, etc. Select either WPA or WPA2, to find your computer's WPA key and insert this key when asked for.
If in step 2, you had reset the modem/router, you will not find any WPA or WPA2 key, and you will have to manually assign one. Select any of the WPA-PSK or any other authentication and assign a key to it. A key can be 8-63 long.
For minimal security, you can choose 8 characters key, like "iN/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBDm+oMp$nrXj5XPVRTvVA5fpwGSGIRVz4RdQ7V3yl$P1NrT9Be".
After you have assigned a key, save/apply the changes and reboot the modem/router.
Note: The procedure shown above is common to most of the modems/routers. If this doesn't apply to you, check your modem/router's manual to find the wireless security option.
Am i able to connect to the internet using WLAN without te security keys (WEP)
If the wireless network that you are trying to connect, is unsecured then you can connect without the WEP key.
but if the wireless network is secured then you will need the KEY or the password for the wireless network. Without the key you won't be able to connect to the secured wireless network.
If you have the router then you can check the wireless settings of the router and find the wireless network key.
Click Here to know more about router and network
I need to locate my network key to connect wireless on my laptop.
1. open internet explorer or any browser, type 192.168.1.1 on address bar..
2. log in to your router.. leave username box empty, type "admin" for the password..
3. Go to the WIRELESS Tab, then click Wireless Security.. you should see there the wireless netwrok key / passphrase
7helpful
How do I find out the security key for belkin router?
if you want to remove security key, just reset the router by pressing the hole or reset button and then type in brower 192.168.1.1 and access in your router.then you can assign new security if you want or leave without security. just connect your computer by hard wire and by same wire other end of this wire will connect to router. don't need to do anythig. computer n router knows best everything else what to do.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
