Question about Toshiba 50HM66 52" Television
I have a Toshibal 50HM66 DLP TV. I purchased it about 4 yrs ago. It worked well for 4 months and the bulb popped, since then I've had to replace the bulb 3 times at a about $150 per bulb. The last bulb works, but periodically the TV screen cuts out and won't come back on. The control panel on the bottom of the screen shows one solid red and a blinking yellow light. I unplug the TV then let it sit for a minute or so and turn it back on and the screen shows ok. However it goes out again after an hour or more. This has been happening for the past few weeks. The TV also says the bulb has malfunctioned. How can I correct this problem?
Posted by anjaco50 on
Anonymous
    New Friend:
I have had the same problem and after several trips to the shop I realised it was caused by humidity. The shop was air conditioned so the problem never happens there. A dehumidifier or air conditioner "solved" the problem.
Posted on Mar 14, 2010
Bp96-02069a - 72" Samsung DLP, 4 yrs old, purchased at Costco. Color Wheel needs replacement but part discontinued with no apparent replacement?Any Advice or is the $3000+ TV trash already?
You can see if one pops up on EBay or look for a parts set on Craigslist. I personally would sell the set for parts. I'm biased, not a fan of DLP's
Hello my name is Amy & I have a 50 inch toshiba dlp (56hm66). I have no lights on or power. It's completely dead!!! I read the manual & followed everything about the lamp, how to restart, made...
Tv have no power at all?U already check the source?Yes,most likely the tv DM power supply board is dead or could be anythings on the highvoltage deflection circuitries on the tv.Check the DM power supply board like for dying or dead capacitors and circuit fuse breaker.Have no skills to do this call and get an estamate by tv Tech. to get it fix.
I have a Toshiba 50HM66 DLP TV. I turn it on and after a minute or two the screen goes black but the volume is still present most of the time. The picture may come back a few minutes later but go again.The...
I hope our expert would have provided you helpful info in chat session, if you still need further help, let me know the steps taken so far to solve the problem of your tv.
Thanks.
SAMSUNG DLP SLIM 50" AFTER I TURN IT OFF IT WONT TURN BACK ON TILL 30 TO 50 MINS LATER THE THREE LIGHTS IN THE FRONT BLINK. iT ACTS LIKE ITS GONA TURN ON BUT IT DOESNT IT JUST MAKES THE NOISE AND FLASHING...
Chris,
I had the same problem. I bought my tv at Best Buy and my warranty included a new bulb for the lamp. They only last about 2 yrs or so depending on how much you watch the tv. You can also buy replacement bulbs online that don't cost too much. BUT, you will need to replace every couple of years. The things you listed are exactly what happens when the bulb goes out. Hope this helps!
Tv does not turn on. it just flashes blue where the power button is. about 2 months ago it was flashing a warning to change a bulb.
must be a dlp purchase a lamp and replace it yourself it is in the owners manual step by step how to change it.
3rd lamp purchased within 2 yrs
There is a slight chance that you might have an issue with a defective ballast, I mean 3 lamps in 2 years, it's too much. The best way to go here is replacing the ballast, that might solve the issue.
2helpful
RCA SCENIUM MODEL D44LPW134 IS MY BULB BLOWN?
If this is a DLP, which I believe it is, your bulb is blown. Look for an indicator light on the front of the tv. After you hear the bulb try to warm up two or three times the indicator light should come on and stay on steady.
I own a 57" Mitsubishi DLP and have replaced the bulb three times now. It was the latest and greatest technology when I bought it, but knowing what I know, I dont think I would buy another DLP.
By the way, get the bulb number then check ebay, by far the best prices.
LAMP JUST WENT OUT
I have a 57" DLP and have replaced the bulb 3 times in 2&1/2 years. I'm not possitive but I think I have 6-800 hrs on it total. Mitsubishi claims it a part they expect to go out, but the told me they typically last about ten yrs. If you have proof of purchase they will send you a new one for free, otherwise it'll cost you about $150 on ebay.
4answers
Toshiba DLP Model 50HM66
You, more than likely, need a new lamp
3helpful
3answers
Toshiba DLP 50HM66
The bulbs for this TV seem to go about every couple years. The price has dropped down a bit. I have found it for 118.00.
Toshiba 50HM66 52" Television Logo
Top Toshiba Televison & Video Experts
Ekse
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
