The owners manual for the Aris21 Bluetooth Headset is available here:
http://files.anycom.com/documents/manuals/cc3101-manual-en.pdfSpecific instructions on how to connect it will depend on your Bluetooth mobile phone model. Typically, this has to be done by going to a setup or connect menu and then selecting the options to discover Bluetooth devices.
Before you start the process, make sure the Aris21 is fully charged and the charging cable is disconnected from it and while the
Aris21 is powered off, press and hold S1 for 10 seconds: red and green LEDs flashing alternately will indicate that the headset is in pairing mode.
Then follow the operating instructions for your Bluetooth mobile phone to start the pairing process. Bluetooth may take several seconds to establish a connection.
Your phone's display should indicate that it has found the “ANYCOM ARIS-21” headset and asks if you want to pair it. You should confirm this. The phone's display would prompt you for a passkey or PIN. Enter a sequence of “0000”.
The headset LED will flash green every 3 seconds, indicating successful pairing. Usually the phone will also ask whether
you want to change the headset's name. It is recommended to approve the ANYCOM ARIS-21 name and not change it.
If pairing does not occur as expected: Turn the headset and the phone off and wait for 10 seconds. Turn the headset and phone on again and repeat all steps from beginning. Pairing does authorize the devices like mobile phones and headsets with each other and only needs to be performed once.
After successfully pairing the ARIS-21 and the mobile phone, you may need to establish a Bluetooth link between them according
to the operation manual of your mobile phone. To establish the link, press S1 shortly. Use Nokia 6130i as an example, the mobile
phone will show „Do you accept ARIS-21 request for connection?” Select YES to establish the link. You are ready to make and
answer calls on the Headset. For other phones, please follow the operation manual to establish the link.
