GPX 2.1 Speaker Bar with ipod Dock  Docking Station, Speaker System Logo
Posted on Dec 27, 2009
My ilive speaker bar IT188B will not play through my television...what do I do?
Paul Tepe
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jul 16, 2010
Paul Tepe
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
28325
Points
22
Make sure that your audio in on Ilive unit is going to your tv's audio out. Your tv may have a setup to able the audio out. Refer to your tv's owner's manual. I have to do this on my tv to my Ilve unit.
1helpful
I unplugged my it188b speaker from my pc yesterday. When I plugged it back in, it wouldn't play, the pc speakers play instead. How do I turn off the pc speakers and get my sound bar to play again?
Check your computer set up. It might have switched the speakers off when you unplugged it. If that doesn't work it could be the jack plug itself. But often you can tell it's faulty due to if it's moved it might come back on again.
Purchased iLive Bluetooth HD soundbar 32", hooked up to TV and makes noise when on a HD channel, Samsung tv
iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat ...
www.amazon.com/iLive...Bluetooth-Sound-Bar/.../B0...
Amazon.com, Inc.
Rating: 3.7 - ‎6 reviews
iLive HD Bluetooth Wireless Soundbar Speaker TV Stand For 20-55" Flat Panel HDTV's Up ... when you purchase $5.00 or more of Qualifying Items offered by D.R. Worth and Sons. ... The iLive Bluetooth HD Sound Bar for 22 - 50 Inch Flat Panel TVs is cleverly designed to ... Click here to make a request to customer service.
Amazon.com, Inc.iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat Panel Televisions ...Bought another for a relative. ... **2 things to NOTE: 1-make sure there is nothing aside from your tv on top of the speaker to avoid rattling, which i mistook for distortion/blown speaker at .... It sounds much better than the Samsung internal speakers.
How to Connect Soundbar to TV ' Audiogurus Store
www.audiogurus.com > Learn: Home > Displays
My ilive speakers IT188b won't play any sound. I'd like to resolder the main audio board, but where is it?!? I got to the insides and pretty much pressed all the connections and they seem in place....
You just want to jump in start soldering without knowing what the cause is???
Do you even KNOW the speaker is the reason? Sources and cables can be the reason.
As always, you should refer to the manual FIRST before coming here.That is where WE will usually start.
For example, there is no troubleshooting section but there is a website mentioned on the last page: www.ilive.net
...which leads to SUPPORT (and contact information, should this not help) which leads to
http://www.ilive.net/store/p/43-2-1-Channel-Bar-Speaker-with-Dock-for-iPod-.aspx
which leads to downloadable manuals
http://www.ilive.net/owners_manual/IT188B-IB.pdf
an instructional insert for changing the clock between 12/24 hr time and FAQs, which discuss your symptom.
"Why can I not hear any audio from my iLive docking system?
When an auxiliary line-in cord is inserted into the LINE-IN jack (on the right side of your IT188B) you will not be able to hear what is connected to IN2 (on the back of your IT188B). Both of these input share the same input function of AV2. To play audio from either of these inputs, press the FUNCTION button until AV2 appears on your LCD screen. If both inputs have connections with audio players, the LINE-IN jack will have precedence over the IN2 jack. Make sure to detach the cable connected to LINE-IN before connecting a device to IN2. You will need an auxiliary line-in cable (3.5 mm mini to stereo RCA cable) to connect an iPod shuffle to this system. Also, there is a Volume Limit option in the Settings menu of your iPod. Make sure that this maximum volume is set to a range that will be audible. Be careful when adjusting your volume level. Higher decibel levels at close range may put you at risk for hearing damage."
14helpful
ILive Bar Speaker not playing sound
I have an iLive bar speaker ipod dock and it has worked great until today. The sound isn't working. You can hear that it is on, but it isn't playing music. The display works and everything. Is this fixable?
2answers
INSIGNIA TV WITH ILIVE BAR. 1 SIDE WORKS
Try swapping your cables from the sound-bar to the TV. If the sound still only plays through one channel but the channel has changed from right to left or vice-versa, then you have a bad cable.
If the performance is the same, connect a different device using the same cables to see if it's the sound bar input or the TV output.
Once you know where the problem is (the sound bar, the TV, or the cables) you'll know what unit needs repair or replacement.
It is entirely possible that a solder joint for the sound-bar has come loose. A soldering pen would easilly fix this if it's a bad joint/connection.
Hope this helps!
7helpful
3answers
My iLIVE mod# IT188b will not turn on.... reset button not working either??? this is the second unit I have had(first one did the same thing)but was able to return without reciept...not the case this time!...
This particular unit has issues with bad solder connections on the main audio board which come loose because the woofer speaker vibrates them loose. I've repaired unit myself with a soldering iron.
Top GPX Audio Players & Recorders Experts
SmartAviator
SmartAviator
 Grubhead
Grubhead
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
