Question about Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum
Dry vac will **** water normally, than the motor makes a higher pitched sound and stops suction. Does this have anything to do with the filter si since it is in bad shape and hasn't been replaced?
ken skalski
    New Friend:
  • 152 Answers
No it usually means that the vac is full and the ball then floats up and blocks the vac so that water doesn't get sprayed everywhere.
Posted on Dec 27, 2009
Testimonial: "Helpful feedback. Thanks, Kurt"
My rigid shop vac 4.0 has no suction
If the motor is turning on then the issue is one of three things blocked exhaust, blocked intake or the fan that moves the air is loose on the motor . The last doesn't happen as much but can. First thing is to make sure the safety ball hasn't become stuck in the intake line. ( this ball stops water from reaching the motor when using it in a wet environment.. If the machine was knocked over while running or was used to suck up water the ball may be stuck) to fix this , remove the wheels from the bottom of the canister , with the machine off raise it and bang it on the floor several times . If you hear a ball drop then that was your issue. If not Disconnect the hose and see if you have suction at the intake. If you do the problem is a blocked hose. Reverse the hose and try sucking the other direction. If the exhaust is blocked the Vac will come on but the machine will sound like it's under load. Try running it without the filters ( do not use in dirt until filter is cleaned and replaced.,). To check the suction fan requires unplugging the Vac from the wall and opening the motor shroud . Locate the fan , see if it is damaged or loose.
Aug 01, 2018 | Shop Vac Vacuums
Lack of suction
You don't say what type of vacuum but it still sounds like a blockage or a split in a pipe... have another thorough look..
Is exhaust air blowing out of the machine... Is the motor running at a higher pitch than normal...?
Apr 16, 2017 | Vacuums
My dc41 stopped all suction. the beater bar spins fine, but no air is moving. as in, is there a separate motor that just croaked?
If your motor is making it's normal sound, it most likely is working. Check for clogs by removing all removable pipe bends and examining visualy, check the hose by running a long broomstick through it. Clean, wash and dry all filters. Check for suction at the port closest to the motor.
Oct 18, 2015 | Vacuums
High pitched sound when power on
I had a vacuum cleaner that did the same thing. My vacuum had three suction levels. The noise level would decrease as I lowered the level. I also noticed that when I turned the vacuum off the sound didn't stop instantly, it wound down/faded off as the motor slowed down. I found the problem to be the bearings in the main motor. I've been told that the motor that powers the carpet brushes can also make the sound if the motor bearing fails.
Dec 29, 2012 | Kenmore Progressive Bagless Upright with...
My SteamVac SpinScrub works fine then all of a sudden, the noise level of the vac seems higher and does not **** up water. I turn off vac then turn it back on, works good for awhile, then noisy, higher...
It sounds as if the ball in the tank in shutting down the suction prematurely. Be sure there is a gap of about 3/4 inch between the top of the filter inside the tank, and the lid of the dirty water tank. Without this gap, suction will pull the ball up too soon.
Apr 04, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I bought my first craftsman 9 gallong wet/dry vac - i do not know how to operate it and I don't want to break anything. I have a pamphlet but it is still confusing. can I pour a few gallons of water into...
Hello again.
When it says wet vacuuming, it means that the vacuum will pick up water, not dispense it. When you are using the vacuum to pick up water, you'll need to remove the paper filter element under the motor, inside the canister, to avoid ruining it. When the filter is removed, you will see a plactic ball inside a cage under the motor. It's purpose is to float up on the surface of the water being vacuumed up, and prevent the motor from getting water into it. You'll be able to tell when the canister is full; the noise the vacuum makes will change and sound higher. Also, the suction at the hose will quit. At that point, shut off the vacuum and drain the water.
Be sure to replace the paper filter when you swap back from liquids to solids.
Best regards, --W/D--
Apr 02, 2011 | Craftsman 17026 Wet/Dry Vacuum
Ridgid 16.5 gallon motor running with no suction
When you use the shop vac for cleaning up water you must remove the filter.
The filter is for dust particles not for water
I would replace your filter and dump the water out from the shop vac, Also after each time you vacuum up water dump it out of shop vac.
I hope this helped you happy new year!
Jun 30, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
I bought a Kenmore canister vacuum, model 116, in April 2007. This morning, the sound of the motor suddenly began to deepen, and I began to lose suction. Normally, if something is clogging the hose, the...
Okay, bear with me. Is it possible you have a suction adjustment, dial somewhere on vac. Check and see and if it does, be sure it's all the way up. Also, try removing hose and run a broom handle fr. one end to the other...BUT be careful not to stretch or break hose, they cost BIG BUCKS.
Jan 17, 2009 | Vacuums
Wet dry vac suction not woking
The wet and dry vaccuums should normally have the dust filter removed when used for wet work. If the filter was left in, it will certainly be clogged and useless. I would suggest trying the unit with no filter, just to check there is good suction. If there is, a replacement filter is required. If there is still little or no suction, then it is possible that there is a blockage within the impeller area somewhere. Wet dust/dirt tends to stick really well to the impeller blades, reducing their efficiency to point of almost no suction. I'm not sure if you can get that far into your unit, if you can, it would be worth using a stiff brush to remove and adhered debris.
Dec 17, 2007 | Vacuums
Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum Logo
384 people viewed this question
Top Ridgid Vacuums Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Bill Boyd
Are you a Ridgid Vacuum Expert? Answer questions, earn points and help others
