Question about National Geographic NG70CA (225 x 70mm) Telescope
Just recieved from father christmas and cant focus into anything
    New Friend:
Joe L's advise is accurate and correct. The maximum magnification of this telescope based on the 70mm objective lens is 140X magnification, however I received this for christmas from my wife and you most likely won't get close to that without some major work to the telescope itself. For one, mine had a very loose and sloppy focuser assembly, the threads and mounts were incorrectly drilled and tapped for the "finder scope", and the "finder scope" is of appalling quality (it's focuser is so sloppy that there is no hope to use it). As usual, the eyepieces supplied are not much better than the one's Galileo made back in the 17th century. Trash would be kind.
HOWEVER, it does have a good objective lens (Acromatic doublet, air spaced) and it's not bad for colour correction. It's short focal length does hamper high magnification views, but keep it under 100X and it does well.
My 2¢ here: shim up the focuser so it's nice and snug, but it still had good movement, buy some better quality eyepieces, and it will give very good views of the moon. With some additional tweaking and careful alignment, Jupiter and the 4 Galilean moons will be visible. Saturn will be a bit of a long shot.
It's also worth mentioning that 1.25" focuser assemblies are available that will fit the optical assembly and with the 1.25" format, the quality of the eyepieces will be much easily obtained.
Posted on Jan 02, 2010
  • 3,186 Answers
This is a small 70mm refractor style telescope.
Put the eyepiece with the largest number written on it into the telescope. DO NOT USE the 2x barlow if you have one. This will double the power of the eyepiece. Your scope is too small to use the 2x barlow.
Now go outside during the day time and practice focusing on a distant object.
This may also help you:
http://www.texasastro.org/telescope.php
Posted on Dec 27, 2009
6ya staff
SOURCE:
My daughter recieved a telescope 50x/100x w/ tripod for christmas and we are unable to see anything out of it? Not to mention that one of the focus lens did not come with a cap.
This is considered a toy telescope. Put the eyepiece with the largest number written on it into the focuser-- DO NOT USE the 2x barlow if you have one. Practice focusing on a distant object during the day time.
Read my tips on my profile page
Dec 26, 2010 | Vivitar (1607225) Telescope
Cant find the valve to put freeon in 2000 ford focus
It is either on or near the reciever dryer in the right rear of the engine compartment. To corrrectly add freon, you need gauges and a refrigerant recovery system
Jul 29, 2009 | 2000 Ford Focus
I CANT SEE ANYTHING WITH THE TELESCOPE.EVEN ON A BRIGHT NIGHT .I HAVE TRIED EVEN USING THE EYE PIECE WITH THE LARGEST INSCRIPTION TO NO AVAIL.MY FATHER INLAW SENT ME THE TELESCOPE FROM THE US THIS LAST...
Sky objects are VERY small the scope must be pointed directly at them--- try for the moon first --- to learn how to focus properly. Just pointing it toward the sky will not do you any good.
Jun 09, 2009 | Bushnell Voyager 78-9945 Telescope
Cannot see anything out of main telescope
Do NOT use the barlow lens-- put the lowest magnification eyepiece into the scope-- practice focusing on the moon -- turn the focus knob slowly in and out until you get a sharp image.
Telescopes only show an area of sky about 1 degree wide or LESS--- this is about the size of the TIP of your finger held at arms length................ your scope is best used at low magnification.
Dec 30, 2008 | Edu-Science (10166) Telescope
Where do I connect the webcam to my harddrive?
I JUST RECIEVED A WEB CAM AND AND DOWNLOAD DISK FOR CHRISTMAS AND WHEN I DOWNLOAD IT IT DOSE NOT TELL ME ANYTHING ELSE. I CAN FIND NO WHERE TO TURN IT ON. HELP
Dec 28, 2008 | Philips SPC 900NC Webcam
Cant see anything
Well you -- like hundreds of other people-- bought a department store telescope. Put the lowest power eyepiece in the telescope-- it's the one with the LARGEST number written on it.
Practice focusing during the day time on a distant object. I know the box said 500 power BUT you will only get about 100 power or less maximum that you can actually use.
Dec 27, 2008 | Vivitar (1607225) Telescope
New bushnell telescope, cant see anything, what am i doing wrong?
Put the lowest power eyepiece in the telescope-- that's the one with the LARGEST number on it.
Go outside and practice focusing on a distant object at least 100 yards away-- turn the focus knob slowly.
Dec 26, 2008 | Bushnell Voyager 78-9945 Telescope
Blurred focusing as soon as turned on
Dear Hokiefootball,
Merry Christmas to you,
Have you Check your Macro and SuperMacro setting whether its turn on or not. The function is for closed up shooting. The sound is from the motorized elements and mechanism in the camera for focusing and shutter adjustment, it is normal. Direct your camera to any object and try to press half-shutter until the target become green. Good Luck
Dec 25, 2008 | Olympus Stylus 1010 Digital Camera
Cannot bring the moon into focus
leave your scope outside for a while so it can cool?
Jan 16, 2007 | Bushnell NorthStar 78-8890 (300 x 90mm)...
National Geographic NG70CA (225 x 70mm) Telescope Logo
177 people viewed this question
Top National Geographic Optics Experts
Marvin
Marvin
james laughton
james laughton
ray gallant
Are you a National Geographic Optic Expert? Answer questions, earn points and help others
