Uniden Cordless Phone Logo
Posted on Dec 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need help with handset registration on uniden 1588
Sam
Level 3:
  • Uniden Master 3,247 Answers
  • Posted on Dec 27, 2009
Sam
Uniden Master
Level 3:
Answers
3247
Questions
0
Helped
1306190
Points
10378
Not sure if you have already got a solution for this problem as it was also listed in the Premium section until a few hours ago.
You must ensure each handset is charged for atleast 20 hours.
Best to de-register each handset first. Follow the menu on base or handset to select de-register.
Then follow the registration process for each handset using the menu function.
Hope it works this time.
1helpful
Uniden EZX290 Expansion Handset Fails Registration to Uniden D1660 Base Unit
Unfortunately, handsets are not universal for Uniden cordless phone systems. The accessory handset for the EZX290 is compatible with the DECT1500, 2000, 2100, 300 and 2900 DECT 6.0 phone systems. The accessory handset for the D1660 is here: https://www.amazon.com/Uniden-D1660-DECT6-0-Cordless-Handset/dp/B004NEUIY2 .
I wish that I had better news for you. Unfortunately, the two systems (EZX290 and D1660) don't use same handshake codes.
3helpful
How do I register my Uniden handset? It keeps saying it tis searching and then out of range even though I have it on the cradle
Which Uniden phone do you have? Some should register with the handset in the base unit cradle for 30 seconds to a minute. Others need to be within a few feet of the base but not in the base charging.
For the models that need to be registered with a multiple step process, first make sure that the handset is fully charged; this could take 15 hours. (Make sure the battery is properly connected; if it is loose, the registration may fail. If the battery may have been sitting in a warehouse for months, you may want fresh batteries even for a new phone.) Make sure that the base is plugged in (power and telephone line). I like to check the phone line with a basic corded phone for dial tone if there are any issues with a cordless phone. With some Uniden phones, a registration problem can be cleared up by disconnecting the battery and then reconnecting it before attempting to register the handset. (Make sure that you do not have more registered handsets than the base can deal with. You may need to deregister all of the handsets and start over. Make sure that the handset is compatible with the base.)
The rest of the process requires you to have the handset close to the base and be relatively quick. (You need to tell the handset to get the registration information from the base and the base to send the information before they time out). For the D1688, at the base, you need to press Menu and go to the Register Accy submenu. Press Select. Then press and hold # on the handset you need to register until you see Registering Handset. Wait for the Registration Complete (or Failed) message.
For the DECT1060, the procedure starts at the handset. Press Menu and navigate to Add. Settings. Press Menu/OK and navigate to Register and press Menu/OK. Select the base number and press Menu/OK. Then press and hold the Find HS button on the base for 3+ seconds until the unit enters registering mode. Now on the handset, you need to enter a PIN that matches the one set for the base. (The default is 0000.)
If you still have problems with registering the handset, then it's likely that the transmitter or the receiver for either the base or the handset may have a problem sending and receiving the codes that synch the base and the handset. Most Uniden phones are not meant to be user serviced for this type of proble. You will need to contact Uniden if the phone is under warranty or decide if you want to replace or repair the phone through Uniden's support.
The manuals for all Uniden DECT 6.0 phones are available as PDFs from Uniden. See http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl for a list of all models or search for your specific model. On the manuals pages, the models are listed in numerical and alphabetical order.
I hope this helps.
2answers
How do i add another handset "uniden 6.0" phone to an existing phone and base unit of the same brand.I need the step-by-step instructions please. thank you!
First make to get a compatible handset.
For the Uniden D1660-2, the compatible handsets are DCX160 and DWX337. Make sure that you have not exceeded the number of handsets that the phone can support. The D1660-2 can support 12 handsets unless you use any DWX337 handsets. Then the limit is 6. (If you have more handsets, you will need to deregister some of them first.) Then allow the handset to charge. If the handset is reading "not registered", then place it into the base unit. You should see "Handset Registering" for about 30 seconds; then it will read Registration Complete. The manual for the Uniden D1660-2 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf . This is the most common Registration for Uniden phones; there are a few exceptions (depending on the base or the replacement handset). Check the appropriate manual (see below to find the manuals).
For the DECT4096, press Menu on the base and then navigate to Handset Register. When you see Handset Registering on the base display, press and hold # on the handset to be registered until you see Handset Registering. (It takes about 2 seconds.) After the display changes to Handset Registered, check for dial tone.
On a few Uniden phones, there is a Page/Handst Register button on the base. On those you navigate through the Handset menu to Handset Register (Menu > Handset menu > Handset Registration). Then press and hold the Page button until you hear a beep. Then wait for the registration to be completed.
Most Uniden manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl . Select your type of Uniden phone and scroll through the list to your model or use the search box to directly search for your phone and the manual.
I hope this helps.
2helpful
HOW DO U CONNECT THE HANDSET TO THE BASE.ALREADY TRIED THE REGISTER BUTTON,DID NOT WORK.IT CAME WITH NO DIRECTIONS,WE BOUGHT AT A FLE MARKET FOR 5 DOLLARS.
Are you sure of the model number? The D1680 should register the handset when you put it on the base for 30 seconds. (You should see Handset Registering followed by Registration Complete.) Then press Talk/Flash to check for dial tone. On this model if the registration fails, charge the battery (or replace the battery and then charge that). Then repeat the registration.
The manual for the Uniden D1680 is available here: http://news.uniden.com/pdf/D1680om.pdf .
For other Uniden phones, like the DEC1060, you need to navigate through the handset menus to find the Handset Registration command. Then press and hold the Register Handset (Find Handset) key on the base for 3+ secondsThen the base and handset will synch. (Low batteries could interfere with the process.)
For the D3288, you access the base menu for Register Accy and then press and hold # on the handset for 30+ seconds. (You will see Registering followed by Registration Complete.)
Additional Uniden cordless phone manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl .
I hope this helps.
(with a flea market phone, my first suggestion is to try a new battery for the handset. They only have a given number of recharge cycles and you do not know the history. However, sometimes the chargers do fail and a new battery will not work. In that case, the phone should be replaced. It isn't worth the cost of out-of-warranty repairs.)
Setting up my outgoing message: just purchased Uniden cordless DECT 1580. Manual says select command 8. How do I find Command 8? thanks, joan
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Thanx
5helpful
My cordless phone says "to register see owners manual for help" How do I get the phone working, it is a uniden DECT 6.0 Model DECT 1588-2
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Uniden Have problem
Dear....Fixya Team,
I'm Soontaree. Thank you for your reply email. I would like to let you know i'm already solved this problem. I just have a look from the Uniden Manual so i just follow them detail like as below,
Thank you for your help i will contact to you later if i have anything problem.
Have a great day.
Soontaree
Registering DSS7905 Accessory Handsets
Your phone supports a total of ten (10) cordless handsets. Handset(s) supplied in the box with the phone base are
pre-registered at the factory. If you purchase an accessory handset, you need to register the handset before use.
Only one handset can be registered at a time. When charged, pre-registered handsets display a handset ID number.
Handsets that have not been registered display.
Before registering the DSS7905 accessory handset, the battery pack MUST be charged for 15-20 hours.
To register the DSS7905 handset:
Place the handset in the telephone base charging cradle to begin registration.
During the registration process, HANDSET REGISTERING will appear in the LCD. When REGISTRATION
COMPLETE. is displayed; the handset has been registered to the base. If REGISTRATION FAILED. appears,
please try these steps again. When you register an accessory handset to the base, the handset ID will be
assigned.
Note:
If an accessory handset has ever been registered to a base, you must reset the handset before you can
register it to a new base. See Resetting the Handsets on page 24.
5helpful
Register additional handsets on a Uniden phone
please help me to register additional head set
MODLE NO IS DXA 15588-2
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
