Question about HP PSC 1315 All-In-One InkJet Printer
I want to scan a document to the computer using my HP psc 1315. When i press the scan button, it runs up like it is going to make a copy or print a document. What am I doing wrong?
Posted by heims24 on
BionicBilly
    New Friend:
  • 27 Answers
Hi Heims,
The best way to do a scan with this psc is to do it from the software on your Desktop.
When you installed the printer the software will have put an icon on your desktop such as HP Solutions or similar. If you double click this icon it will bring up a panel where you can select to scan a picture or document etc.
Do the scan from this panel and it should all follow from there.
If you don't have an icon for HP on your desktop, open Programmes, find the HP printer programme and double click it to open the panel.
You can also click on the program and drag it to your desktop which will create an icon on your destop for you.
Good luck
BillyWiz
Posted on Dec 27, 2009
I downloaded HP PSC 1315 All-in-One Print/Scan/Copy Device Printer but on my pc it is showing HP psc 1310 series .is it the same ?.i am not able to print a word document ,when i click print it goes to...
1.Download from here the correct driver
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=374569&lang=es&cc=mx&taskId=135&prodTypeId=18972&prodSeriesId=360489
2.Uninstall all about hp printer software that you have
3. Power cycle the Pc
4. Reinstall the new downloaded driver
5. Finally plug in the printer and turn it on
How do I fax a document
HP psc 1315 does nopt support fax feature, it support only print, scan, copy
I dont know how to scan from my printer hp psc 1315. printing and copy fine. please help me
Hello, Windows XP provides a basic set of scanning drivers, also referred to as Windows Image Aquisition (WIA) drivers, which you can use as an alternative to scan a document when you cannot scan using the HP drivers. You might choose to use these scanning drivers for one of the following reasons:
  • Your product released before Windows XP and HP has not released drivers that support scanning for your product.
  • You have not installed the available HP software that includes scanning.
  • You are troubleshooting a scanning problem and trying to identify the source of the problem.
Scanning with Paint To scan a document using Paint in Windows XP , follow these steps: NOTE: Before you begin, make sure that the product is connected to your computer.
Click Start , point to All Programs , point to Accessories , and then click Paint .Click File , and then click From Scanner or Camera .Make any desired setting changes.Click Scan .
How do I scan a document using the hp psc 1315 and then find it on my computer? I press the scan button and it seems to scan, but then I can't find the newly-scanned document anywhere. There needs to be an...
The scan button is setup to push the scan to an application, if you uninstalled the HP scanning software, it isn't going to go anywhere. If you didn't, it will put it into your documents folder under "My Pictures" in an HP created folder.
That said, you can also go into any application, like Word. then click "Insert > Picture > From Scanner or Camera" and carry the image in directly.
52helpful
12answers
HP PSC 1315, scanner and Mac os
To scan documents on Mac OS X using your HP PSC 1315, you need to download HP's "Device Manager" software which is available here : http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-41992-1&lc=en&dlc=en&cc=us&product=374572&os=219&lang=en
I just installed the software and am now scanning problem-free.
Scanner
Check the power and the data (USB) cables in the printer...check both ends...
Check :-
# The printer powers on properly
# There also can be problems with the printer driver
# and also internal printers....
Try reinstalling the printer driver...
<PLEASE RATE ME AS FIXYA>for my help......................
229helpful
7answers
HOW TO SCAN ON HP PSC 1315
i have a Vista system and an old hp 1315. the CD driver that came with it includes some very useful software that cannot be installed in my laptop. according to the hp website, that's because Vista comes with a compatible software for my hardware. checking Windows Help & Support gave me this solution:
Open to Windows Photo Gallery, click File then click Import from Camera or Scanner.
i did exactly that and it worked!
i hope this was of some help.
4answers
HP PSC 1315 Scanning problems
download software for hp psc 1210 printer
WILL NOT COPY
Dear, after changing the cartridge, printer print a test print. OKAY. Take that test print and put it on the scanner (printed area should on the side of mirror) then press "scan" button on your printer "bottom left". When the light stop fluctuating. Keep out the paper from the scanner. After this Printer will work properly
HP PSC 1315 All-In-One InkJet Printer Logo
k24674
Mike
