Question about Sony KP-61HS10 61" Rear Projection Television
Tv looks like the edegs curve and is blury - Sony KP-61HS10 61" Rear Projection Television
Posted by elvalogan on
Anonymous
  • 647 Answers
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Posted on Dec 27, 2009
REAR PROJECTION RCA R52WH74 ,TRIPLE LINES , BLURY, COLOR OFF CURVED SOUND GOOD
You can determine if you have a true convergence problem or just need an adjustment very easily. Take a look at this youtube video to find out.
Hope this helps!
Dec 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
The picture is curved at the top and bottom and it blury
its good that you give it to an expertise to handle it.....but if u insist and costly, open the back cover, their should some adjustments keys their that helps in adjusting images...one for the 3 colour (blue,Red,Yello) and one for sharpening pictures (making it clear)....for safe use give it to an expertise to minimize further faculties
Oct 04, 2009 | Televison & Video
The picture is blury
The convergence is dead,need a convergece kit,U know how to solder right?Tries these websites.for the kit.Tv Repair World.com, Shopjimmy.com,Ebay.com or Partstore.com.
Sep 08, 2009 | Sony KP-53HS30 53" Rear Projection...
Red & Green outlines but only on left/center portion of screen.
Its a convergence problem. You may want to check the site www.tvrepairkits.com. Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to tvrepairkits.com I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Aug 18, 2009 | Sony KP-46WT500 46" Rear Projection...
MY RCA R61WH76 61 INCH TV IS BLURY AND LOOKS LIKE IT HAS 3 PICTUR
RCA Scenium Profiles HD61 TV IT'S AT 480i how I get at 1080i or 720i please help....thanks...
Jul 02, 2009 | RCA R61WH76 61" HDTV
Red and green curved lines when the screen is dark
Your convergence board is going out. this will have to be replaced. i would take a look at the main logic board as well. it could have minor point breakage.
Feb 09, 2009 | Sony KP-57HW40 57" Rear Projection...
Focus block is at max still blue
the convergance amplifier have failed there are two of them they need to be replaced. there may be some pico fuses and resistors also. convergance failure is the most common rear projection tv it makes the set appear blury.
Feb 21, 2008 | Hitachi 46F500 46" Rear Projection...
Sony KP-61HS10 61" Rear Projection Television Logo
118 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
