Canon PIXMA  MP530 All-In-One InkJet Printer Logo
Posted on Dec 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MP530 error code 5700 - Canon PIXMA MP530 All-In-One InkJet Printer
Anonymous
Level 3:
  • Master 434 Answers
  • Posted on Dec 27, 2009
Anonymous
Master
Level 3:
Answers
434
Questions
0
Helped
190881
Points
1456
Please be sure you do not have a paper jam. Bits of paper can be left internally which may impede the paper path.
Otherwise you may try to reset the device:
1) Press and hold the <On/Off> button until the display on the machine goes blank. (If this is unsuccessful, unplug the power cord).
2) Wait approx. 10 seconds and power back on. Wait until the printer completes its startup routine before trying another print job.
3) Your MP 530 requires repair service.
How to remove Canon Printer Error Code 5700?
The error displayed on Canon Printer number means sheet feeder needs to be replaced, it can be that gears in the printer and/or sensor have become broken or faulty. 5700 is a ASF cam error most likely which is called ASF cam sensor error.
How to Fix Canon Printer Error 5700? - SlideShare
Canon MP530, would only print half of a page then quit and give me error message 5700. I would pull the paper out and shut down and would start and print only half of a page and stop. I would take out...
This error is referring to the ASF assy (Assembly frame which means the paper feed section)
This paper sheet feeder assy is a extremley complicated piece and is therefore not really repairable. You will need to take the machine to a canon repairer for a new assy sheet feeder to be fitted. It takes a trained engineer about 2-1/2 hours to fit one as the whole machine has to come apart and the new feeder has to be aligned while fitting. Its a job i always hate having to do. You dont have any other options i am afraid. Srri to bring you such bad news.
1helpful
Canon pixma mp530. Error 5C00
it means Purge cam sensor error
visit this link for more info and possible solution
http://pcmediks.blogspot.com/2010/11/canon-pixma-error-codes-and-solution.html
We have problem with my printer''Canon PIXMA MP 520''. It shows error 5700 and aasks us to refer to Manual which we do not have. Do you know what is the problem?
Reply part #1
The 5700 error is showing that the Auto Sheet Feeder paper sensor has an error and needs cleaning or changing to fix this error. This can also be caused by problems with the paper pick up mechanism and roller so make sure you thoroughly dust them with a soft brush or clean them with a cotton bud and isopropyl alcohol. Also preferably vacuum out the whole paper path with a soft brush tool with the printer switched off at the mains. If cleaning the sensor and cleaning the paper path does not clear the error then you will have to call as service engineer and possibly have the sensor or paper feed mechanism serviced or replaced.
9helpful
2answers
Cannon pixma ip 4600 error code 5700 - paper jam
The error code 5700 is the sensor error.Replace the sheet
feed unit and then adjust the timing of the paper feed gears.
Sharp FO5700
I have never seen this error code on a sharp FO 5700 are you sure that is the right model # or error code. I even did a search in the FO5700 service manual(no luck). I believe I have seen this code before on a sharp copier.
2answers
old marine
old marine
ZJ Limited
ZJ Limited
