My panisonic has the blue green and red is out of wack and cant fix it they say i need codes
Posted by jonyr73 on
  • Anonymous May 11, 2010
    CONVERGENCE PROBLEM. THIS IS A GEOMETRY CORRECTION CIRCUIT AND IF THE CUSTOMER CONTROLS WONT CORRECT IT YOU WILL NEED A PARTS REPLACEMENT.
Anonymous
  • 647 Answers
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Posted on Dec 27, 2009
Pink and green shadows. convergence out of wack
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 30, 2011 | Panasonic PT-51HX40 51" Rear Projection...
Magnavox 51MP392H Rear Projection Television convergence problems
You need to try to adjust it with the original remote in the TECH mode---you can save the adjustments there--
With the set on a video input with nothing connected:
hit the following buttons: 0 6 2 5 9 7 STATUS
The menu should appear with choices---green(do not adjust green) red to green, blue to green etc.
On that initial menu will be a item that says store or save. Depending on the remote you have once you select red to green (cursor on remote) a grid of lines should come up---on screen will be instruction--menu to adjust and or status to navigate.
When you have the red--to green adjusted hit the status button until it takes you back to the menu where Store or save is listed and right cursor on it.
This will store the adjustments.
Go back by selecting blue to green and adjust that also and when done go back and save it.
Turn the set off to exit the service mode and see what you have---IF THE SET DOES NOT RETAIN these adjustments made in the Tech menu something is wrong with its DCU--digital convergence unit---that stores the adjustments.
Let me know if you have questions as I am here to help people.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 17, 2009 | Philips Magnavox 51MP392H Rear Projection...
Red tube out!!!!
Your TV is not DLP it is projection it has 3 tubes RED /GREEN /BLUE cost of new tube $500.00 used if you can find one maybe $100.00
Feb 28, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Blue bulb is lit but no picture
the messed up colors are probably from a burned out convergence chip. not too pricey to fix.
Feb 17, 2009 | Philips 55PW9363 55" Rear Projection...
Panisonic projection tv pt-53wx52f
There is a mechanical adjustment on the tubes themselves when it was dropped it could have knocked it out of alignment, or the Convergence ICs are bad with is a common problem with CRT projection tvs.
Mechanically adjusting the tubes can be tricky I wouldn't suggest working on it unless you have some kind of experence with tvs. But if you do adjust the red and blue to the green.
Oct 06, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Tv repair
There is no chip for the green, Unless he is refering to the convergence Ics as there are two of them and one controls red convergence and half green, and the other controls blue convergence and the remaining green. Those ICs are 20.00 each and take about 30 minutes to replace both. Is your set experiencing a 3D type of picture?
May 24, 2008 | Mitsubishi VS-55601 55" Rear Projection...
Convergence
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 24, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Convergence problem???
you must move red and blue lines into the green. change red to blue by useing the select button on the remote. till all convergance lines are white
Jan 12, 2008 | JVC AV-48WP30 48" Rear Projection...
C Color is way outta wack on my 56 inch pilips rear proj tv. HELP
Oct 28, 2007 | Philips 60PP9352 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
