Intel D845GLLY Motherboard Logo
Posted on Dec 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I replace 256 MB SD RAM with 512 MB DDR1 ram in intel 845 glly mother board?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
334
Points
I have installed RAM of 256MB each (2slots total 512MB ) and system BOOTS UP, but it keeps restarted on every 5 minutes.
Please advice
It is 845 GLLY Original and 1.7ghz.
Alun Cox
Level 3:
President:
  • Master 2,679 Answers
  • Posted on Dec 27, 2009
Alun Cox
Master
Level 3:
President:
Answers
2679
Questions
0
Helped
689758
Points
8444
Anonymous
Level 1:
  • Posted on Feb 04, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
334
Points
Run with single module & find which one faulty.
1helpful
Is it possible to add 1GB DDR1 RAM 333 MHZ to INTEl D101 GGC
u can use the 1gb ddr1 ram,if the sound is coming then may there is two problem
1.may be the ram is damage
2.your motherboard is not supporting 333mhz bus support
try to find 400mhz ram instead of 333mhz
I have compaq presario 5000 series...and iwant upgrade my ram ...i have 128+128 sd ram so how much i upgrade my ram...can i upgrade 512+512 sd ram OR 256+256 sd ram...thank you
the RAM upgrade will depend on ur motherboard capacity and specification.
u need to check ur MB manual
if ur MB can have only SD RAM then only SD RAM upgrade is possible...DDR will not work....
so be careful while buying ur RAM
intelD845GLLy MB...the following details are from the intel website
http://www.intel.com/support/motherboards/desktop/d845glly/sb/CS-012825.htm
System Memory Features
The D845GLLY board provide the following memory features:
  • Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
Caution Do not use ECC DIMMs with the Desktop Board. Using ECC DIMMs could damage the Desktop Board.
Integrator's Notes:
  • Registered DIMMs are not supported on the Desktop Board.
  • This Desktop Board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated on this board.
Note To be fully compliant with all applicable PCI33 SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
hope this helps
Reg....bye
1helpful
2answers
I have intel 845 glly desktop board with 256 mb SDR. When I added 128 mb SDR in the second slot it is not recognising it. How to add 128 mb SDR with 256 mb SDR. When I fix 128 mb ram in first slot and...
1st try to exchange the cards in the slot.
2nd try another card
3rd ur RAM slot may not be ok
4th ur RAMs may not be compatible
5th ur new RAM card may not be ok
use same type of RAMs, and same size...
if u have 256, add 256
if u ahve 128 add 128
if u have SDR then dont add DDR
getting compatibility is little difficult...
some times no combinations can work...
note...technology keeps changing...so a old RAM card that was bought years ago may not be compatible with a new RAM card....
even i got all my old RAM cards(256+128) removed and got 2 - 512mb of the same type fixed...even i had issues with my RAMs for 6 months...
2answers
Memory cards
Normally 512MB is a good configuration of Ram to work with Windows Xp Sp2 but you have clean your temporary files frequently
Increasing RAM will not give you much speed difference because first you have study the Motherboard Bus speed and the cache memory - Actual speed increase from those things and the compatibilty.
Changing Ram you have to determine what type of ram and its bus speed whether its a SD Ram or DDR1 or 2 I hope now days SD ram cost more because its outdated and DDR1 is also bit costly than DDR2.
Hothawk
Compatilblity with 845G mother board
try update the system bios because there were motherboards that had compatibility problems, this board is not a new one so it should work with your processor
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
