Question about Kenwood CT 401 Hi-Fi Stereo Dual Cassette Deck Single Dual Cassette Deck
Midi M-85 Midi M-959 Compact Audio System protect mode keeps coming on when trying to play CD or tune radio.
Posted by marion_wroug on
1 Related Answer
caroldon
  • 17130 Answers
SOURCE: compact audio systeem protect mode keeps coming
It is not so easy to probe into to find a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Posted on Jul 01, 2011
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
Feb 13, 2016 | 2013 Toyota Highlander
How to reset my sony mhc-gs100??? it keep saying power protect...
Your stereo went into protect mode to prevent complete failure of the amplifier inside that radio. Most of the time this happens from playing the stereo real loud for a real long time and it overheats. Most of the time disconnecting the receiver/stereo and letting it cool all the way down or at least 5 minutes and then reconnecting it to the power source will reset the protection mode. You want to make sure you are keeping the radio cool. Don't stack anything on top of it and try keeping a small fan blowing on it to expedite the heat out from the unit. Also turning it down every now and then to let everything cool down a bit will help prevent it from going into protection mode as well.
Mar 24, 2011 | Sony MHC-GS100 CD Shelf System
RCA RS2603 digital audio system stopped playing CD's. Double cassette tape deck works as does radio, but cannot play CDs.
chack and see what type of CD you are using. i have been having the same issue. i actually found out that the CD's i use to play songs, and etc are "CD-R". the compatible CD's for my (RCA DIGITAL AUDIO SYSTEM RS2603) sterio are CD-RW's or compact disc that you find on production music like albums, etc. hope this helped !
Jan 03, 2011 | RCA RS2046 Shelf System
Owners Manual for Kenwood Car radio Model KDC-M4527
KDC-M4527
CD Receiver with WMA/MP3 decoder Built-in
Audio Features
- 4 x 50 watt maximum output power by MOSFET Power IC
- 1 RCA preout, 2 Volt
- Separated tone control: Bass/Mid/Treble
- Source tone memory
- Balance/Fader/Loudness control
- System Q: Sound control with pre-programmed tone curves
- Auxiliary input with optional unit (CA-C1AX or KCA-S210A)
- Attenuator (-20dB) with smooth volume return
Tuner Features
- 24 presets: 18 FM, 6 MW/LW
- K3I clean reception Tuner
- Radio Data System (RDS) with Radio text
- Auto memory entry (AME)
- Up/Down seek tuning
- Local Seek
- FM Stereo/Mono selector
- Tuning mode : Auto1/Auto2/Manual
- DAB reception with optional unit KTC-9090DAB
CD Features
- CD-R/RW compatible
- 8 times over-sampling
- 1 bit D/A converter
- S/N ratio: 105 dB
- Dynamic range: 93 dB
- Channel separation: 85 dB
- MP3 decoder with ID-3 Tag display
- MP3 decoder MPEG-1/2 Audio layer-3
- WMA decoder: windows media audio
- CD-text
- Random/Repeat/Scan Play
Changer Features
- Dual changer control capability (CH1/CH2 & AUX)
- CD-Text with compatible units
- Disc Name Preset System with compatible units
- Disc & Track repeat
- Disc & Track scan
- Disc & Magazine random play
General Features
- Removable faceplate
- Protection case for faceplate
- Disabled System Indicator (DSI)
- Mono Colour LCD display
- 14 segments x 8 characters
- White LED display backlight
- Selectable key illumination (red or green)
- 24 hours clock
- Auto Dimmer
- 2 way telephone mute
- All off select (20/40/60 min.)
- Built-in fuse/coil
- ISO A/B connector
- Remote sensor for optional remote control unit
- OEM steeringwheel remote hardwired connection
thats the most i could get go here http://kenwoodusa.com/Contact/ and have them send u one hopw that helps.
Oct 01, 2009 | Kenwood Car Audio & Video
Car Stereo in Protected Mode will Not Play Radio or CD
try the small reset on the lower right hand side of the player it fixed mine
Feb 03, 2009 | Kenwood KDC-MP228 CD Player
Tascam 144 sony acid pro 6 no sound from midi track
It sounds like you may be confused on what the MIDI part actually does. MIDI records your performance, not your sound. Then you assign and play back the recorded performance to either a virtual instrument (in which case you should here sound from your computer) or to a real physical MIDI capable instrument (in which case you would here the sound coming from that real instrument instead of the computer).
The ends of the MIDI cables themselves are identical, not IN or OUT.
Feb 01, 2009 | Tascam US-144 Sound Card
Hxd7 protect
Don't buy a stereo that prints up 'PROTECT MODE' and then does not tell you how to cure it. This is a good way of getting people to buy a new one only live and learn do not buy the same manufacturer again. I have a nice just out of warrenty JVC that when I switch it on sits there grinning at me with 'PROTECT MODE' showing. Yes I have entered cash protect mode and decided I am not going to buy another JVC.
Jul 26, 2008 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Protect mode
i try to turn the stereo on a message saying "protect" comes up and then it shuts off
Apr 28, 2008 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Tuner seems to go out of tune after it plays for about 5-10 minutes
if you have soldering iron ,solder the rf coils ,this colis many cases have poor soldring wich will off tune agc.therefore you notice channels off tuned.
Oct 19, 2007 | RCA RS2664 Shelf System
Amp goes to protect mode only on cd play
Do you get adequate bass on the radio, or is it a bit quiet on the low-end?
Apr 15, 2007 | Sony CDX-SW200 AM/FM Compact Disc...
Top Kenwood Audio Players & Recorders Experts
Michael Thomas
Michael Thomas
Kardoc
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
