Nintendo Game Boy Advance SP Console Logo
Posted on Dec 27, 2009
Screen freezes after gameboy logo appears - Nintendo Game Boy Advance SP Console
Anonymous
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Dec 27, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
19
Questions
0
Helped
4774
Points
41
Make sure your slot and game is attached properly.
clean the game slot with wet napkin and game ,....................sometimes dust the problem.
10helpful
3answers
Ive turned on my pokemon emerald gba game but the screen that says gameboy is just frozen there leaving no nintendo logo
Here is the perfect solution, : Guess what, that happened to my 30 minutes ago when i felt like playing my gameboy with pokemon emerald. This is an easy to solve problem, and it will work every time. This is a step by step procedure please follow the instructions one step at a time !! :::
Step one: Close the gameboy and take out Pokemon emerald
Step two: Blow into the bottom of pokemon emerald [to get dust out]
Step three: Blow into the place where you place pokemon emerald
Step four: Put it back in and test it, it the nintendo sign is all blury and weird, continue
Step five [Only do this if it still isnt working] Keep turning off the game boy and turning it back on
These problems are caused by damage done to the system or dust in the game cartridge.
If this hasnt worked,, Try it again :)
Well...ive turned on the game pak for pokemon emerald ..but there was only the gameboy logo...the nintendo logo didnet pop up like it usually does ..leaving only a blank screen that just says gameboy.
Easy fix: Take out the game and blow into the bottom of the game and blow into the place where you out the game into the gameboy, and try again, If it doesnt work try again and then turn off and on untill the Nintendo logo comes clear
Ive turned on the game but no response.it only says gameboy ,but the nintendo logo does not pop up leaving only a blank screen that says gameboy.
The Nintendo logo not showing up but the GameBoy one does means that it can't detect the game. Take the cartridge out and put it back in again. If that doesn't work, clean the contacts on the cartridge. As a temporary fix, you can blow into the cartridge (the bottom where the shiny metal lines on the board are) or you can clean the cartridge by using some rubbing alcohol with q-tips to wipe the metal contacts on the cartridge to clean it and let it dry for an hour.
My gameboy advance sp will load the gameboy screen and then freeze up. it sometimes freezes at the screen,or occasionally the screen goes white and freezes. i have tried to blow in the game but it does...
It is possible the interior of the game is scrached or dusty (do not know how). You may want to open the game casing and look at the memory chip. If that does not work, I suggest, you purchase a cleaning kit. I hope this helped!>0(peace)
2answers
My Gameshark for Gameboy Color says "Manual Upgrade"
The game shark most likely needs new firmware downloaded on to it.
1helpful
No image on Gameboy Advance SP
It is possible to buy another Screen for the GBASP, however it would probably be less work and less trouble just to go to your local Gamestop and buy a new SP for 40 bucks.
My LG HE500 freezes on the loading screen
type 2945#*# and a engineering menu will appear,select factory reset and may your problem will be solved,try other features appearing on engineering menu.
Hello, when I turn on the gameboy color it stays on the logo screen. This happens even if I insert a game. Any ideas?
Are the batteries new?
Insert the game before you turn on the gameboy. Try blowing air in the connections area of the game and in the connections area of the gameboy itself.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
