Brother HL 1440 Laser Printer Logo
Posted on Dec 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A friend has built me a new HP computer. Previously I had a Brother HL-1440 printer working with my old computer. I went to Printers to select the compatible Brother HL-1440 for my 'new' computer, but there was no HL-1440, but other versions of Brother...
Kevin Groce
Level 3:
President:
  • Master 216 Answers
  • Posted on Dec 27, 2009
Kevin Groce
Master
Level 3:
President:
Answers
216
Questions
Helped
86961
Points
5366
You can still use the printer go to brother and download the xp or 2000 driver it should work
or do a microsoft online update and it will update itself
I need to update driver to windows 8
Brother has most of their drivers on their web site. However, the HL-1440 drivers are built into Win8. Plug your USB cable into your computer and the driver will load. You may need to use Windows Update and check the optional updates to find the driver. (If you use a parallel port (assuming one is on your computer, you will need to use the Add a Device wizard.)
I hope this helps. Most of the documents and drivers for the HL-1440 are here: http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/monolaserpri/hl1440_all.html?reg=us&c=us&lang=en&prod=hl1440_all .
I need software for my new computer
You candownload the Brother printer drivers from their support WEB site. Please clickon this link and select your model printer to download : -http://www.brother.com.au/ProductsSolutions.aspx
Looking for new printer driver for brother hl 1440 and windows 7
As per the printer manufacturer website, Brother Hl-1440 printer is not compatible with Windows 7.
http://www.brother-usa.com/Printer/ModelDisclaimer.aspx?Model=HL1440#SysReqs
However, you may download & try installing the XP drivers for the printer in Windows XP mode.
To install in compatibility mode:
1.a. Right click on the setup file of the driver.
b. Click Properties.
c. Click Compatibility tab.
d. Under compatibility mode, check mark "Run this program in compatibility mode for:" and select "Windows XP (Service Pack 2)" from the drop down list.
e. Click Apply and then click ok.
2. a. Under "Privilege level", click "Run this program as an administrator".
b. Click apply and then click ok.
3. Install the driver successfully and restart the computer for the changes to take effect.
MEMORY UPGRADE FOR BROTHER HL-1440 INSTRUCTIONS
if its a new computer follow the instruction of your printer and / or take it in to Best Buy or something
Need driver compatible with Brother 1440
I tried HP Laserjet IIP and it works. Thanks for the help!
2answers
HL-1440
You can download the printer software from this link so you can reinstall it to your computer, just select the operating system that your computer is using
http://solutions.brother.com/hl1400/download/drivers.html
Brother HL 1440 Laser printer-horizontal black streaks
check your drum may the corona ware is broken . change the drum.
1helpful
Brother HL-1440 Printing Preferences Language Problem
I had the same problem. I finally totally uninstalled the printer from my computer, downloaded the "new" software from the Brother site, and reinstalled it. This is what finally worked for me (WinXPProf.).
Connecting printer to Windows Vista Laptop
I have a new HP laptop with Vista Home OS, and I just installed my HL-1440 with a driver that was installed automatically in the "New Printer" procedure in Windows, and it works perfectly.
--Gabriel
Norman Weimar
Norman Weimar
k24674
