Cnet (CWR-854) Wireless Router (cwr854) Logo
Question about Cnet (CWR-854) Wireless Router (cwr854)
I have a new laptop with Vista installed and I can connect to the CNet wirless router (CWR-854) but can't get internet access?
Posted by charlie159 on
  • 1 more comment
  • charlie159 Dec 27, 2009
    Hi Sai,
    I have checked the connections and think the Router needs a firmware update (its currently reading version 1.03.03.03 last updated Mar 18 2005 20:39:57). Do I need to update the firmware? Is there a link I can use for free updates? thx Charlie
    I have checked all the LAN/Router connections. I think the firmware may need updating to run Vista or Windows 7 as the version is
    Current Firmware Version:
    1.03.03.03
    document.write(''+U_E[4][L_S]+': ');
    Firmware Date:
    Is there a URL I can find free updates? Will this allow me to connect to the internet?
    thx
    Thx. I have checked all the LAN/Router connections. I wonder whether the firmware needs updating as the current Firmware Version: 1.03.03.03 Firmware Date: Mar 18 2005 20:39:57
    Is there a URL site I can access free updates so WIndows Vista or 7 can work? thx
Anonymous
  • 4,889 Answers
Please check the status of the internet/DSL light on the router. Also please check the connections if you have done it right. The internet cable should go into the WAN port behind the router.If you want to connect the router to your PC as well then take a LAN cable, connect it to one of the LAN ports behind the router and connect it to your PC. If you have done all this right and still have problems, then it may be configuration issue. Please let me know if this is the case so that we can re-configure the router.
Regards,
Sai.
Posted on Dec 27, 2009
  • Anonymous Dec 27, 2009
    Sorry I took a Siesta! I am looking for the firmware now..
    Here is the link to the firmware update for your router. Please read the instructions carefully and download the correct version.
    http://www.cnet.com.tw/download/cwr-854....
    Sai.
I cant install my cnet wireless g router cwr-854
you should contact your internet provider for professional advice. it's most likely free and faster than asking nerds on the internet who doesn't know anything about your specific router-model ;)
cheers
What is it used for?
You can use this wireless router to connect different wireless devices together. Each device with a wireless network card (computer, phone, gaming system, printer, etc.) can connect to the router without a cable. This will form a network where information can be shared.
The main purpose people use this for is to connect their network to the internet. As long as the router is connected to your internet, every other wireless device can also connect.
Thanks,
Pat
Cannot connect to internet, already configure my wireless CWR-854, thru 192.168.1.254, when im in internet, my deafault gateway is 192.168.1.1, please help
online user manual is here http://www.cnet.com.tw/download/cwr-854.htm If you goto page 37 it show the dhcp range . Make sure your pc cofiguration is set to dhcp - automatically obtain and IP and DNS - this is explained on page 10/11 try this Start>run{vista/7 search box}>cmd>ipconfig /release Start>run{vista/7 search box}>cmd>ipconfig /renew see if that produces the correct info
How to use my Cnet CWR-854 Router as a wirerless antenna for pc.
You can't really use a router to connect to another router, you can sometimes use them as an "Extender" for range, but not as a WiFi card, they simply aren't made to operate that way.
1helpful
I dont know how to access setup wizard for cwr-854 cnet router
To access Router type that --> http://192.168.1.254 into your browsers address bar, a password & logon box should appear, The USERNAME is root The PASSWORD is 1234
Now you should be able to access wizard.
Here is a better manual.http://www.cnetusa.com/eng/Manuals/Wireless/CWR-854/CWR-854%20ver%20F%20Quick%20Install%20Guide.pdf
Trying to access 192.168.1.254 for siemens se567, followed advice to go to run and cmd ping, don't understand other go to access point, my situation is the older couple I live with have wirless internet in...
The internet connection has a security that's why you can't access the internet. The only thing you have to do is to know the wpa password of the router.
This router has a default username and password to configure all the settings. This is the manual for Cnet CWR-854 Router:
http://www.cnetusa.com/eng/Manuals/Wireless/CWR-854/CWR-854%20ver%20F%20User%20Guide.pdf
It seems that the router is already configured by an authorized person, the best thing you should do is contact the authorized person that knows everything about the router.
I want to connect cnet cwr 854 as an Access point AP,
ENABLE YOUR WDS ENTER THE MAC ADRESS CIENT
2answers
Is there a conflict between linksys BEFW11S4 router and CWR-854 cnet router?
No problem at all. The router can function as bridge with no conflicts with other routers.
Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
comier957
No access to web based utilty
Seems like you need to verify that the web management interface is at the address your specified or that your PC is indeed wirelessly connected to the CWR-854.
The following suggestions assume you use Windows XP as your OS:
  1. You need to connect to the CWR-854 via a network cable (one end connected to your PC the other to a LAN port on the CWR-854) initially.
  2. You can try to access the web management interface at the IP address you expect, i.e. 192.168.1.1 or you can verify the IP address by finding the Default Gateway your PC is issued by the CWR-854 from:
  • Right clicking on the tray icon of the network connection, choose "Status" then click on the "Support" tab to see the Default Gateway.
  • OR click on "Start" then "Run...", type "cmd" then type "ipconfig" and read the Default Gateway value under the section for the "Ethernet adapter Local Area Connection".
Use the Default Gateway value as the new address to use for the web based utility if it differs from what you expected.
Top Cnet Computers & Internet Experts
 Mike M
Mike M
NOEL
NOEL
matt
matt
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
