Dryers Logo
Question about Dryers
Press the start button on dryer, it hums but wont turn. With 2 people pressed the start button again, held the door switch, reached in turned the drum, it hummed stopped humming then no more nothing. Kenmore 90 series dryer 1999.
Anonymous
    Scholar:
  • 66 Answers
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Posted on Dec 27, 2009
1helpful
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
The drum in my kenmore elite he3 wont turn
That is a bad sign. If the buzzing starts when you press the start button and stops when you release its almost safe to say that the motor has a dead short or grounded out and causing that to happen. You can check the start switch by getting a multimeter and with the dryer unplugged take the wires off the switch, place a lead on each pin and press the start with meter set for continuity. If it shows continuity when presed and stops when released your motor is shot and needs to be replaced.
Now if you press the start button and the machine starts to hum and continues to hum its possible that something has gotten caught in the blower wheel and binding the motor up. Depending on the make and model the location and access to it vaaries.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
LE5200xtwo dryer press start button and it hums but wont spin
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Apr 17, 2011 • Dryers
Kenmore dryer model # 110. 79902890 press the
you have a problem with a component called a capacitor.the capacitor stores an electric charge.this charge gives the motor the "kick" needs to start.if you have a faulty one the motor will hum because it cant turn.it should only be replaced by a competent appliance technician.
Oct 07, 2009 • Dryers
Humming noise when i press the start putton
When I push the start button it would hum if I hold the button to long and then it would cut off.
2answers
Gas dryer hums when I press the start button but won't start
hi thats a sign of a faulty motor . replace the motor thanks the appliance doc.
1helpful
The Drum on my LG DLE2512W Dryer will not turn
no problem with motor or control board. fault is with the motor capacitor only. this is often attached to the motor or near it. the value of the capacitor will be printed on it (usually about 8uf) and you should be able to source from an electrical spares shop
Open Questions:
0answers
Lg dryer DLG1701W te1 and te2 codes blower thermostat keeps blowing as well Hello my lg dryer model number DLG1701W has been having issues for the past 3 days. Dryer finished a normal cycle and wouldn't start up again after swapping load of laundry out. When I tried starting it up again it was throwing a te1 code. Looked up the code on lg's website and tried doing a hard reset. Tried a few more times again and this time I was getting a te1 and a te2 code. Looked up the te2 code and decided to pull the machine out and inspect/clean the exhaust. Exhaust wasn't clean but air flow also wasn't restricted and the flaps on the outside of the house were on and in good shape. Hook the machine back up again and tried starting it again with attempting to reset again with no luck. I decided to pull the machine apart and test the thermistor with my fluke meter. found the thermistor on the exhaust side was reading but was all over the place. 13 ohms while in the machine. Down to 9 ohms when removed. After letting the thermistor sit for a little bit it was reading 11 ohms but was all over the place in that range between 11.08 to 11.96. Wasn't sure if that was normal or not so I decided to replace it. Tested the other thermostats while I was in there and found both thermostats on the gas range were reading normal but the thermostat on the exhaust side of the unit was faulty. Not reading at all. So I replaced the thermistor and the thermostat on the exhaust side. Button the machine back up and go to test but initally the same error codes were coming up te1 and te2. Finally after a few more attempts the dryer started. I had it set on a high temp 40 minute cycle. After about 10 minutes of it running though the barrel stopping turning and the gas range shut off. But it didn't throw any codes. The display continued to countdown and all the other light were working as if it was still running. Shut it off a few times and tried starting it back up and the same thing would happen. Countdown would display and countdown. All the lights would light up as if it was working but the barrel wasn't turning. And the gas range wasn't running. I walked away for a little bit to think about it (approximately 2 hours) when I came back to it, the machine was doing the same exact thing as what it would initially do. Click and display a te1 or a te2 code. I pulled the machine back apart again and currently still have it apart. The thermistor seems to be in a continuous 11.25 ohms range with the ohms dropping when touching the sensor it self. The thermostat that was just replaced has blown once again. Any insight on why this could be happening would be very much appreciated Update. Checked all the components again including the motor. Motor checked out good. Put everything back together again. Try it again a few times. This time everytime I tried it, the machine would start and run for a 4 to 5 seconds then shutdown and throw back the te1 and te2 code. Note: it never has both the te1 and te2 code at the same time. Each time it's tried it 1 or the other
Top Dryers Experts
Marvin
Marvin
David Shaub
