Question about Kodak EasyShare One Digital Camera
Easy share email will not connect to server - Kodak EasyShare One Digital Camera
Posted by sjkritz on
Anonymous
    New Friend:
I wanted to use my ISP' email server, faster and no kodak advertising attached, here's what I did in version 7, now also version 8.
First click on "email" on the left side of the easyshare screen, then click on email settings at the top of the page and make sure that email with attachments is checked.
then go to the easyshare program folder normally at:
C:\Program Files\Kodak\Kodak EasyShare software\bin\ini\VistaEmail.ini
find the file ESAcct.ini and double click it.(you may want to make a copy of it somewhere just in case) in the file you will see:
[ACCOUNT_INFO]
EMAIL=
PW=
enter your ISP's mail server address at the EMAIL entry and your email password if required by your ISP at the PW like so,
[ACCOUNT_INFO]
EMAIL=mail.smtpserver.com
PW=mailpassword
of course these entries have to be YOUR server and password not the examples above. save the ESAcct.ini file.
Now find and double click the VistaEmail.ini file, again you may want to save a copy of it also.
Find the line
SMTPServer=picturecd.kodak.com
and change it to your smtp server address, just like above,
SMTPServer=mail.smtpserver.com
save this file. If easyshare is open you may have to close it (shut down easy share) and re open it.
If you are connected to the internet you should now be sending your photos through your ISP's mail server. No more long delays and no more kodak advertisements with your emailed photos!
David
Posted on Jan 29, 2010
Nokia Email is not working in E63
Well its easy to setup email on the phone. What server you are using ? POP from gmail or any other ?
If you are not so technical then you may use third party email application for your mobile phone, you may find them on mobile sharing sites like whatsmobi.com, gallery.mobile9.com etc... Free Java games download games for Java
May 26, 2014 | Nokia E63 Cell Phone
Tip
Sharing files
<span>Pando is a simple application that lets you send files of up to 1GB through any email. It also allows you to share photos, videos and documents through its dedicated instant messenger. After installing the app, you need to select the files and folders that you would like to share and immediately a copy of the files you want to share starts getting stored on the secure servers of Pando. The recipient will receive a email with a .pando attachment which when opened by the recipeient will allow him to download it from the files from the Pando server.</span> <span>(<a href="http://www.pando.com/download">http://www.pando.com/download</a>)</span>
on Apr 10, 2011 | Computers & Internet
Tip
Accessing emails on email server through HAMACHI VPN INSTALL HAMACHI ON BOTH...
accessing emails on email server through HAMACHI VPN
INSTALL HAMACHI ON BOTH THE SERVER AND THE REMOTE CLIENT . THEN JOIN THEM ON TO THE SAME NETWORK, FOR FURTHER NOTES ON HAMACHI HOWTO GO TO : HAMACHI HOW-TO
CONNECT THE TWO AND PING EACH OTHER BOTH WAYS, THEN TRY TO ACCESS THE FILE SHARES ON THE SERVER TO MAKE SURE THE CONNECTION IS REAL AND LIVE.
YOU SHOULD KNOW THE USER ID FOR THE EMAIL ADDRESS YOU ARE GOING TO DOWNLOAD AS WELL AS THE PASSWORD.....
CONFIGURE YOUR EMAIL CLIENT....
IN THE INCOMING AND THE OUTGOING SERVERS OF THE EMAIL CLIENT YOU HAVE TO PUT THE NETWORK NAME THAT WAS GIVEN ON THE EMAIL SERVER TO THE HAMACHI CLIENT.
NEXT IS TO ADD THAT NAME AND THE HAMACHI IP ADDRESS IN THE HOSTS FILE SO THAT THE DNS IS RESOLVED CORRECTLY.....
ONCE THAT IS DONE THE REST IS AS WE DO IT ON THE LOCAL AREA CONNECTION WALLAAAA!!!
WE HAVE THE EMAILS DOWNLOADING.......
HOPE THIS WAS HELPFUL...
on Mar 10, 2010 | Computers & Internet
Benefits and drawbacks associated with the adoption of network cpmputers
depends on the setup of the network for one. if it just simple setup then allows sharing of files, a single internet connection, some standalone capability for any problems if the computers get virus infection, internal emails/memos and some network back ups. downside software licence for many separate computers.server based. the computers can access one source for information. allowing users to log in and get their files from any machine. easy backups, licensing can work out cheaper for many machines. very easy to share information. however vulnerable to viruses, can be expensive to maintain if external company setup. servers can be expensive to buy and everyone has a problem if the network crashes, often no one can use the computers if not working.
networking is generally a positive thing and id recommend it.
hope this helps
Apr 05, 2012 | Network Computing Devices Computers &...
Xerox scanning error 027-516:server connection error in smb
This means that your machine cannot connect to the network share to which it is supposed to write the scanned documents.
There may be several causes:
- if it worked before, perhaps the server or computer with shared folder to which the Xerox unit is configured to write files is unavailable/switched off, or the shared folder is not shared anymore or has changed security permissions, preventing the Xerox from writing, or the share name has changed
- if it never worked, perhaps the Xerox needs configuring prior to use (how it should deliver the faxes, via network share or email). Refer to it's manual on how to configure scan delivery.
Jul 24, 2011 | Computers & Internet
I have a problem with a printer which is connected locally to a pc (comp1) on the network. I can access it from one pc but can not access from 3 other pc. I have three printers locally connected and...
Hi Shueb,
First off, I assume if your running a network, you'd have a server based product running. If so, I would have the server manage the printer as a shared printer. This can be accomplished by setting up the share either in your management console or your active directory. Then the server will administer the rights to the printer. If your running a network with just workgroups, then you will have to right click the printer and go to share and security. From there go to permissions and make sure that the users on those machines have permission to access it.
A real easy way to connect a shared printer on a network is to browse through the entire network icon, and click on the machine that is sharing that printer, and when you see the printer right click it, and go to connect printer, and that's it. As long as you've got all the drivers for all the different OS's on the differnent machine, it will install the driver and give you access.
Good Luck,
Mark
Jan 15, 2009 | Computers & Internet
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Internet Sharings
hi
first of all can u plz tell me how do u connect to internet like u use a connectiode or something if yes its very easy u just need to right click on the connectiode & just go to properties click on the advance tab & under the internet connections sharing put the check mark on allow other network user to connect to internet through this computer internet connection thats it. u will be able to access the internet on all the pc on ur network. incase if u still have any problem just let me know & also provide the details on ur network like how u connect, any router hub or switch is been use for connecting pcs etc
Oct 02, 2008 | Computers & Internet
Windows 2003 server standard edition
You have to enable routing and remote access in win2k server to share your internet connection
Follow these steps
Goto start--> programs-->administrative tools --> routing and remote access
Just click it
In the action menu click add server and select your server in the list
Once routing and remote access is properly installed in the server
Go to the client give gateway address to your server address and any internet DNS server addresses , and you can now acccess the internet
You can also use any internet sharing software , In this case i sujjest to use Sygate Internet sharing software
Good Luck
Jan 27, 2008 | HP Compaq ProLiant ML330e Server
Download MAil From JAna SErver
Hello Sir,
As my internet is shared through cc proxy
I have to put proxies to all of my programs so that they can run.
Unfortunatelly the only one I cannot get running is outlook express.
When I try to edit the outlook proxy settings it sends me to Internet Explorer's settings
(which makes me think that outlook and internet explorer share the same proxy settings).
The strangest thing is that IE runs with no problems
but outlook express cannot connect to the server.
It says that the server cannot be found (both incoming and outgoing)
Could you please advise me how to make the outlook running.
Also I had try to install squid 2.7 proxy on win2k8 but i m getting some error with squid service is not runniong on win2k8 it says create services failed ...please advice me which proxy server i can use our network ( my task is only i want 2 secure internet & block some sites on my internet and outlook should be a work )
Thank you very much.
Have a great day,
Regards
Ashok
Jan 17, 2008 | Computers & Internet
Kodak EasyShare One Digital Camera Logo
Top Kodak Cameras Experts
Steven Wander
Steven Wander
Are you a Kodak Camera Expert? Answer questions, earn points and help others
