LG Original HBM-770 Bluetooth Headset Logo
Anonymous Posted on Dec 27, 2009
Need pass key 4 my bluetooth lg hbm-770 - LG Original HBM-770 Bluetooth Headset
  • Anonymous Dec 27, 2009
    need passkey 4 the lg hbm-770 bluetooth
joviton007
Level 2:
Guru:
  • Expert 200 Answers
  • Posted on Dec 27, 2009
joviton007
Expert
Level 2:
Guru:
Answers
200
Questions
0
Helped
115186
Points
655
Hi
you can put 0000 on your cellphone and tell the other person with whom you want to share files to put the same number"
"both of you"ll should use the same it can be any number"
2answers
How to connect lg hbm-730 bluetooth to dv4 laptop
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
4helpful
Need pass key from lg hbm 760 to use on ps3
Just went through the exact conversation with my Verizon people. The pass key number is 0000. It worked:-)
4helpful
Need passkey for bluetooth device
Well, unless you personally changed it yourself, the defaults are 0000, 2468, or 1234. Google all the default keys for a bigger list.
11helpful
2answers
My voice is garbled and the people I call using a LG HBM-770 bluetooth wireless headset can not understand me. Suggestions??
tried pairing with a different phone and turned up the volume button...don't know which change made it work but it worked fine. So I'm guessing it might have been the voume was not set correcttly.
1helpful
1helpful
3answers
Pass key
All LG Bluetooth Pass-Codes are 000 or 0000.
Top LG Radio Communications Experts
ADMIN Andrew
ADMIN Andrew
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
