Question about Microsoft Xbox 360 Console
Hi... i have three lights flashing? can you help please
Posted by mo_murtagh on
Teajunkie
    New Friend:
    Problem Solver:
  • 11 Answers
You have the dreaded red ring of death.
You would be better off sending it away for a Infrared reflow of the GPU this costs about £40 and there are plenty of sites that do them like www.Xbox-reviver.co.uk
Xclamp kits are a waste of money TBH and rarely work for more than a week.
Posted on Sep 09, 2011
Anonymous
    New Friend:
Itz rrod......
or may b due to power failure,
chck unplugging all plugs frm ur 360 n reconnecting it, if it works then its nt a rrod, if it doesnt ...
then itz rrod, u need to send your xbox 360 to fix it..
or need to get it xclamped:
here is the whole process to do a permanent fix *xlcamP* of rrod on ur xbox 360:
http://www.megaupload.com/?d=2LEW79G4
Posted on Dec 27, 2009
Why doesn't it work?
please provide model number of the Dishwasher and the exact keys where the three lights glow.
Perhaps a photo without flash will help
Mar 29, 2016 | Samsung Dishwashers
What do the three lights on the top right of the 920c HP printer indicate?
The first light (from left to right) is the Print Cartridge Status.
This will flash if one or more of the ink cartridges are low or the cartridge incorrectly inserted. Also flashes if the wrong type of cartridge inserted.
If the ink is low the light will stop flashing when you open the top cover of the printer.
The second light is the Resume Light.
This will flsh when anaction isequired such s loading paper or clearing a paper jam.
The third light is the Power light.
This will flash green when the printer is printing.
Hope this helps you. Thanks for using FixYa.
Nov 18, 2011 | HP DeskJet 920c InkJet Printer
Tv comes on for 2-5 minutes then goes off
I can help you to solve your Sony KDF-E60A20 tv problem.
Does tv turn back on itself OR standby light start flashing?
If standby light flashing, please count how many times it flashing after three seconds long pause and let me know to diagnose problem.
Thanks.
Dec 04, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Hi, the three green lights on my dell 100l flashes when ever i plug it in.when i press the switch button it stops flashing but does not come on. please help
Take the battery out, connect the power plug and see if the laptop runs without the battery connected, the main battery may need to be replaced.
Aug 28, 2010 | Dell Latitude 100L Notebook
Xbox 360 Console: my xboxs 360 has three red lights flashing...
Hi Sir
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Please Rate
May 17, 2010 | Microsoft Xbox 360 Console
The two coffee lights and the water light are flashing
Had the same problem. I sealed my lips around the steam wand and sucked as hard as I could, first with open steam knob, then with closed. Obviously there was some air left inside from steaming before. Machine worked fine afterwards.
Nov 30, 2009 | Starbucks Saeco Italia Digital Barista...
Three red lights flashing
Greetings,
The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console or power supply.
Please check the the link below of Microsoft support. I am sure this will help you.
http://support.microsoft.com/kb/907534
Sep 26, 2009 | Microsoft Xbox 360 Console
Three flashing red lights on xbox 360 console
Wow, 4th? That's horrible! Hopefully the following helps you out! SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 05, 2008 | Microsoft Xbox 360 Console
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Microsoft Xbox 360 Console Logo
85 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
James Bradburn
James Bradburn
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
