Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
Posted on Dec 27, 2009
Screen has color. but no picture. only moving multi colored vertical lines. tv does have sound, but no picture.
  • 1 more comment
  • suge0317 Dec 27, 2009
    Coax...coming from cable box to tv.
    hmmmm, now the screen is sorta marbled dark-ish blue. if it's helpful, the tv is less than a year old.
  • Anonymous May 11, 2010
    what kind of cable are you using, HDMI, Coax, PrPbY or ?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 28, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
572
Points
Unscrew the cable off the cable box on the out to TV end, then screw it back on. You may also try a different type of cable, like HDMI or component cable.
1 Related Answer
Anonymous
  • 320 Answers
  • Posted on Oct 18, 2008
SOURCE: Multi colored vertical lines
Probably you need an optical block, but it would take a tech looking at it to be sure
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Polaroid FLM 3232 Color problem
If you typed in the right model number this is a LCD TV and won't have a color wheel...Check all the power supply voltages and see if they're all ok, if they are I'd replace the main board and see if that fixes it since you don't have sound or picture
Flickering multi-colored line in the middle of the screen.
You have a failure in the vertical deflection circuit. This could be either a bad vertical chip, the power supply that runs the chip or a bad capacitor in that circuit. This is usually a repair best left to a professional. There is a small possibility that it could be bad solder connections. If genlty tapping the unit temporarily solves the issue you can try and resolder the pins on the vertical chip LA7841 is the part number. There is also a resistor 1 ohm 1 watt. If that resistor is open you can assume the IC is bad
1helpful
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
