Master
- Posted on Dec 27, 2009
Re: Can not set-up surround speakers through avr unit or...
Hi and welcome to FixYa,
Initially, have you tried a full / hard RESET of the Denon AVR-4802? Doing so would allow you to start clean/fresh reverting to factory defaults and remove any glitches, errors in settings, configuration including memories, presets and user preferences. If have not been tried:
- switch OFF the AVR-4802 and unplug from the wall outlet;
- press and hold the DIRECT buttons and stereo button;
- without releasing the buttons, plug the unit back into the wall outlet;
- release the buttons only when the display is blinking.
Offhand, should the above be not corrective, then it would be a hardware fault on the power outputs of the amp designated for the surround. Options then are:
- consider a DIY (do-it-yourself) repair if and only if very familiar with electronic components & circuitry, use of a DVM/VOM, a soldering iron/station and safe working practices with electrically powered devices. Access to a Service Manual or at the very least, a schematic diagram would be a necessity;
- should you be uncomfortable with a DIY, perhaps your best bet would then be to seek the services of an authorized Hitachi Service Center or a qualified professional.
Good luck and thank you for asking FixYa. Happy Holidays.
