Question about RC Thunder Tumbler Rc Car
Our thunder tumbler only goes forward on back two
Our thunder tumbler goes forward on back two wheels even without holding down the action button. Why doesn't it go forward on all 4 wheels ?
Posted by larryt24 on
Anonymous
    New Friend:
  • 11 Answers
There is no problem that is tha way it is sopoesed to be
Posted on Dec 29, 2009
How do I fix the remote on the RC Thunder Tumbler RC Car to prevent the tire from spinning as soon as the remote control is turned on?
Use the throttle trim control to try and adjust this unwanted throttle application out. Refer to the user manual on how to trim the remote functions
Oct 17, 2016 | RC Thunder Tumbler Rc Car
Two of the remote control cars we bought are broken
Sorry but these are very cheap and no parts are made for repair.
May 05, 2017 | RC Thunder Tumbler Rc Car
Something's Stuck!
Can't you move the wheels around to jiggle it out? If you can't you will need to preform some surgery from the one wheel, just keep track of all the screws when disassembling it; that is a last resort
May 19, 2013 | RC Thunder Tumbler Rc Car
Thunder tumbler
My Thunder tumbler works perfectly every day, until now, one of the wheels won't seem to move I looked inside and I saw a Lego brick was in there. There's in opening in the car which is where the peice is. So when I try to make it move only one other wheel moves. HELP ME!!!!!
Dec 26, 2012 | RC Thunder Tumbler Rc Car
Instruction manual thunder tumbler
1 of my back tires move but my other wont
Dec 25, 2012 | RC Thunder Tumbler Rc Car
Change frequencies on thunder tumbler
How to Chang the frequencies on the thunder tumbler
Jan 08, 2012 | RC Thunder Tumbler Rc Car
My son received a thunder tumbler remote control stunt truck yesterday, (5/15/11) and it is already broken. My younger son broke the truck where the attena connects, however, I glued that and the truck...
try contacting the company. if the car wheels are broke or dangeling you would need new wheels. if the wheels arent the problem it could b the turning starvos
Aug 26, 2017 | Cars & Co Rc Remote Control Thunder...
The reverse won't work. Push the button and it just keeps going forward. When filling bobbin the needle shaft still goes up and down even when the dial has been unengaged as directed
Ok, you have a couple things going on here. You need to remove the top cover of your machine. Let's address the reverse first, look down into the top of your machine and press the reverse button. There should be some action there. If not your button is dirty and needs to be cleaned. If there is movement check for a small set screw attached to the lever on the knob. This may need adjustment.
On the handwheel, you need to take the smaller wheel off and pull the handwheel as far off the machine as you can without damaging the belt.
Clean the area where the handwheel goes over the shaft with canned air - make sure you clean all the way around.
That should do it.
Aug 22, 2010 | White Sewing 1409 Mechanical Sewing...
RC Thunder Tumbler Rc Car Logo
791 people viewed this question
Top RC Toys Experts
Tom Chichester
 Mikey
Mikey
ray gallant
Are you a RC Toy Expert? Answer questions, earn points and help others
