Toshiba 43HX70 43" Rear Projection Television Logo
Posted on Dec 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The red convergence on the right half of my screen is way off and will not change. any suggestions?
Anonymous
Level 3:
  • Master 668 Answers
  • Posted on Dec 27, 2009
Anonymous
Master
Level 3:
Answers
668
Questions
Helped
190370
Points
1925
I would replace the Convergence IC's. They should be STK-392-110's. It should cure the problem.
They are typically mounted to heavy duty Heat Sinks and located generally on the Video Board. You should replace both of the IC's as a pair. I would also make sure you use Heat Sink Compound on the back of the new IC's when remounting them.
I hope this helps,
Skyassoc
Experiencing convergance problems in upper left hand corner on Samsung PCL541R mostly red shifted to right and down Bottom right half of screen is clear Do I need to replacer convergance chips?
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
I'm having trouble adjusting the picture. The left half is clear while the right half is blury.
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
I have a Panasonic PT-53WX54J that will not Converge
you need to replace or have professional convergence amplifiiers. If know how to desolder and solder you could repair yourself or in home professional tv repairperson will cost you $275-$400. The convergence adjustments via remote are half the battle the IC's loose clarity over time.
The Screen looks 3D & Colors don't line up on my big screen????
If the convergence is off more than 1/2 inch or so you can't adjust. you have a failure of hardware. most likely the output IC. This set has 2 outputs for convergence. Each output contains 3 circuits, Six circuits altogether 2 red ,2 blue and 2 green. The normal customer adjustment will only alow adjustment of blue and red. They should be converged onto the green. There is a much more complex adjustment in the service mode for Geometry and convergence. These adjustments are only needed when you replace a failed componnent like the output ic. These ICs have been upgraded several times since the production of this set. The latest and most powerfull version is STK394-160. If feel up to it I suggest changing both outputs and the corresponding output resistors. Then do a complete geometry and convergence alignment.
2helpful
2answers
Convergence on lower half of the screen is off, green arc appears
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Half the picture is good, other half is off center
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
1helpful
Convergence adjustment for red and blue
Press the MENU/SELECT button
on the remote control to show the
on-screen menu.
Press the CURSOR RING
RIGHT
to enter the PICTURE menu.
DOWN
repeatedly until CONVERGENCE
is selected.
RIGHT
to enter the CONVERGENCE
menu.
RIGHT
to enter CONVERGE RED
mode.
LEFT, RIGHT, UP, or DOWN
to
adjust the cross image until the color
outline around it is gone.
Press the STATUS/EXIT button
to exit the menu from the screen.
Blue Convergence
Blue convergence IC is bad, but change both as red wont be far behind they are cheap about 10.00 ea at the following link.
http://electronix.com/
26helpful
10answers
Hitachi television repair
how do i access the convergence on my big screen
3answers
Colors separated
You need change STK392-560(can use STK392-570)
I guess it happend when holding bolts weaken to radiator.(Check other STK on next radiator)
You have to change STK on right radiator.
Disconnect small connectors. You can l leave Hi Voltage two lines(RED). unscrew board.
Pool board out.
Unscrew STK. Set board verticaly. Just pool STK bu pincet and heatup solder. One by one...
Clean halles.
Set new STK with thermopasta on board in to hallsradiator. Screw up.
Wet contacts by liquid fluse. And sosler them.
Clean up by alcohol...Check for short by lense...
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
