Samsung LN32B360 32 in. LCD HDTV Logo
Anonymous Posted on Dec 26, 2009
I just upgraded my LN32B360C5D firmware to 1016.1,
I just upgraded my Samsung LN32B360C5D firmware to 1016.1, and the sound stopped working
  • Anonymous Oct 27, 2010
    well i f you a have a samsung TV you will see that there is no warning ragarding updates, so I got a new TV from them or I would sue them
    Thank you for not helping. :)
    P.S.
    In case someone else had the same problem, samsung already posted the firmware to correct that problem.
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Oct 26, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3742
Points
8
If you weren't having problems, you shouldn't have updated. Samsung on their site says DO NOT UPDATE if you are not having problems... don't fix what isn't broken, now live with your mistake.
Samsung LN32B360C5D Repair
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Check the voltage that comes to the back-light inverter board; from the main power board. The absence of this voltage too can be the cause.
Dell c1760nw erreur 009-654
I was able to resolve the dreaded 009-654 on my c1765nfw.
  • Download/install the usb driver for the printer
  • Connect the printer to a usb port on my computer
  • Download the latest Dell printer firmware driver
  • Re-power the printer on with a toner cartridge removed
  • Run the Dell firmware upgrade program, it should recognize that the printer is connected and will load the firmware
  • When the firmware installation is completed, restart the printer and everything should be working again.
This solution may work on all other Dell printers that experienced the same error.
S/N AZA43CRSA16199J MODEL LN32B360C5D BUY IN 2009 POWER GET OFF SCREEN GET BLACK NO SOUND
Thanks for stopping by.
Typically, for the symptoms you have described - the power supply board likely has failed capacitor(s). If you were to remove the back of the set - you'd probably notice the power capacitors leaking or bulging.
For your Samsung LN32B360C5D CLICK HERE to see your board/replacement.
The big yellow capacitor in the middle is the likely culprit.
While you have it open - check the fuse near the power plug as well.
This is not something that will correct with a reset or button press - it will require repair.
If you have it to a repair shop - expect a $75 component repair charge. If the board cannot be repaired - the board itself is $89-$135 plus 1 hour shop labor to replace.
Thanks!!
Where can I get a free user Manual for Samsung LN32B360C5D
From Samsung's official site would be the best source:
Go to http://www.samsung.com/us/support/downloads/LN32B360C5D and click on the PDF icon next to the User Manual
Doesnt play all blu-rays, sound some times is quicker than video, movies stop for no reason
Are you running latest firmware? If not. upgrade is the must. Visit samsung website for upgrade file and the guide.
Sound
the ear piece needs to be replaced or reflash the firmware or upgrade it on the phone
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
