Vivitar ViviCam 8025 Digital Camera Logo
Question about Vivitar ViviCam 8025 Digital Camera
When i try to turn my flash on it says Macro Mode
Posted by ladiitemptat on
Anonymous
    Brigadier General:
  • 11,967 Answers
You're in macro mode and the flash won't function. Check your manual to find out how to get out of macro mode. Most cameras have a button or a dial with a picture of a flower representing macro mode. Find that and change it.
Posted on Dec 26, 2009
1helpful
2answers
When I try to turn my flash on it says macro mode, What is this and how do I fix it?
Macro mode is for taking pictures of subjects very close to the camera. In this mode the flash is disabled.
Without knowing the model of your Digital Concepts camera I can't tell you how to take it out of macro mode. If there's a button on the back marked with a flower icon, press it. Otherwise look in the menu.
My camera works fine in all ways except whenever i turn the 'flash' on and try to take picture the green light just flashes repeatedly and it won't take a picture at all, but if i turn the...
Referring user guide:
Are you press ligthly? if press half and ligthly, it will not take the picture.
When you have using macro mode, you need to disable Flash mode.macro mode will show picture(flower) and avoid hand shake during this mode.
When you take in 10cm range in macro mode, it will take more longer time to autofoucus, you need to be freeze a while until it take the picture. The best it, try to take picture in without you inhale. it will avoid you from shage
Try using in different DIS mode when you using the flash.
In some mode, it will have twice flash. First flash it will check the condition and wait until second flash and dont move your camera.
Some condition, you will get the picture is white, it because from dust atmhospheric that we cant see. it reflective to ur flash.for the best picture, you need to try in different mode and different condition. that will make you as proffesional. this camera have many mode that you need to understand. training urself to be perfect. download manual and test your camera
4helpful
The flash is in macro mode. What does that mean and how do I get the flash to turn on?
The macro mode is for taking pictures of subjects very close to the camera. The camera disables the flash in this mode. There's a switch on the left side of the camera, near the USB port. Slide this switch away from the flower symbol and toward the mountain symbol to switch out of the macro mode.
2helpful
Why does my camera say macro mode when i try pitting the flash
There's a slide switch on the left side of the camera, near the USB port. Slide the switch away from the flower icon toward the mountain icon to switch it out of macro mode. The macro mode is for taking pictures of subjects very close to the camera, and the camera won't fire the flash when in macro mode.
My vivitar vivicam x029 will not let me turn my flash on. It says no flash in macro setting? how do i turn it on
The flash is disabled in macro mode. There's a slide switch on the side of the camera, near the USB socket. Slide it away from the flower and toward the mountain to switch out of macro mode.
Whenever i want to turn the flash on, i press the flash icon and it says "macro mode" on the screen.
You can't use the flash in macro mode. Macro mode is for taking pictures of objects close to the camera.
To switch out of macro mode, slide the switch on the left of the camera, just above the USB port, away from the flower icon toward the mountain icon.
I try to turn the flash on and it says Macro Mode. HELP????
The macro mode is for taking pictures of subjects very close to the camera. In this mode the flash is disabled.
There's a slide switch on the side of the camera, near the USB socket. Slide it away from the flower and toward the mountain to take the camera out of macro mode.
22helpful
2answers
When i try to turn on my flash, it says 'macro mode' what does this mean, and how can i get my flash working again?
Do you have a button with a picture of a flower on it? Press that to remove macro mode...then your flash may work.
How do I set the camera to Macro and can I turn
Page 16 of the user manual explains how to set up the camera for the macro mode. If you are using regular macro mode then you would also need to set the flash mode to off if you do not want it to fire automatically (page 15 of the user manual refers how to disable the flash). If you are using the super macro mode then the flash would be set to off by default.
2answers
Use of macro digital feature
hi,let me just inform u that the macro mode is only for outdoors.So on the side of the camera u will find a sliding switch.Just slide it to the opposite direction to turn off the macro mode.Since u wanted to take pictures of jewelry pieces,turn on the flash if u have one and then take a closeup shot with good lighting conditions.If its too bright then use only the flash,if u r not satisfied with the quality then use only lights and then take a pic.Still face any prob plz get back to me.
Top Vivitar Cameras Experts
David Shaub
Steve
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
