hello, it is either the lense of the hi fi system that may be faulty, therefore, if that is the case you take it back to the dealer that sold it to you.
or probably the disc is not compatible with the HI-FI system.
I have the 405 and a Samsung 3600 which has onboard DTS Master/ Dolby True HD. Out of the 6 movies I 've watched, only 2 have given me Dolby Digital. Bottom line: If the movie doesn't have DD, you cant get DD on the 405. I thought just about all blu rays had DD but its not so. Its time for us to upgrade!
You probably have burnt the dvd disc using a video format that is not compatible with your player.
A lot of DVD players will not play .AVI or DIVx files that are commonly downloaded.
Your DVD player manual should list the formats it will play.
Convert downloaded movies to a compatible format before burning to disc.
There are several conversion programmes available via the web - at a cost of approx $50.00.
AVS4U works ok.
If your receiver has a multichannel input and the player has the multchannel output then that is the only way you can get surround sound from it with source inputs that it cannot decode, such as DTS. The player will then do it alone.
However, in the setup menu of the blu ray player you should be able to change the audio output to downmix to 2ch audio...at least you'll get to watch the movie.
I have a similar set up. For yours, I would run one optical from your Sat box to your 407 and connect the DVD player optical to the Kenwood as well. This will allow you to get whatever your watching, DVD or Satellite to your speakers. For Video, use the component cables to connect DVD player to TV. For the SAT box, coaxial to TV or S video to TV will give you about the same video quality. I hope this helps. A couple of suggestions: Your new screen size will greatly magnify the quality of your video, what looked good on the Sharp may not look good on the Samsung due to the size difference. I REALLY suggest you get a new SAT box with a HDMI connection. Also you can get a blu ray player in the $120 range. The Blu ray will play blu rays and upconvert DVDs to a higher quality picture through its HDMI connection. You will be amazed at the difference HDMI will make on how your TV will look!
