Cell Phones Logo
Posted on Dec 26, 2009
Phone will not turn on even when it is on the charger the key pad light turns on for about 15 seconds then shuts off
Motorola electrify m wont turn on and had no lights when on charger
In the unlikely event that your phone stops responding to touches and key presses, try a forced reboot-press and
hold both the Power and Volume Down keys for about 15 seconds. If necessary, hold the Power key to turn your
phone back on
Sanyo zio 8600 wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jan 11, 2013 • Cell Phones
My htc freestyle wont turn on
5.Wait 10 seconds.
Step
Thanks
My phone is not turning on at all
5.Wait 10 seconds.
Step
Thanks
Oct 27, 2012 • Cell Phones
2answers
My Android 4 wont turn on
5.Wait 10 seconds.
Step
Thanks
Oct 07, 2012 • Cell Phones
Motorola 9500 sat phone wont turn on, red light comes on.
5.Wait 10 seconds.
Step
Thanks
Acer 5570 southbridge overheats and shutsdown
well,if you r able to get to bios then check power managment sction and reduce CPU speed and try to deactivate one of the peripherals that is responsible of thi shorting out= over warming.
as long as the southbridge chip over warms every time you turn on you laptop thats mean the S.B is facing a shorting out on it IC.
you can clean underneath/surround it.
plz rate.
Key stuck in ignition
Be sure its all the way in park or try neutral.Its possible that security system does not recognize the key. Is security light flashing or on steady? Shut all doors and windows,trunk,hood, turn off all accessory's,roll down drivers window, turn key off and remove for at least 1 minute, insert key into ignition, try to start leaving key to run position for 20 minutes, turn key to off,wait 15 seconds, try to start again leaving key to run, wait 20 minutes, turn key off,wait 15 seconds, try to start, again leaving key to run, wait 20 minutes, turn key off, wait 15 seconds, try to start. This should relearn key code. It may relearn after 1 learn cycle and start if system is ok. Hope this helps and that the weather is dry and warm for this procedure! This is not always a fix, but works most of the time.
RAZOR V3
it shows that you are having flex cable issues - common problem with the v3. you would have to bring it to a local repair shop or order a keypad flex and button flex cable to do yourself.
the parts are about $15-40 and a shop will charge about $25 to install
if all else fails contact me and we can help arrange it.
Phone cant be turned on
it is problum from power switch replace it.
Top Nextel Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Nextel Cell Phone Expert? Answer questions, earn points and help others
