Question about Excalibur. K9-MUNDIAL-SS Entry Level Auto Alarm with Dual Zone Shock Sensor
Trying to program a new remote to my car alarm ''excaliber'' k9 remote
Posted by gguerra99 on
Anonymous
    New Friend:
  • 41 Answers
Turn key to on position push valet 5 times then hit lock on the remote
Posted on Feb 03, 2010
Can a new remote be programmed if alarm is set?
Hi Kim, When you ordered the new key the dealer should have asked for the chassis number? That gives them the codes to pre program. so that it should activate and deactivate the alarm, if that is the problem! ? Regards John
Jul 02, 2012 | 2000 Pontiac Grand Prix
Hi im anthony and i had bought a laptop from a guy and it has k9 web protection on it and im tryn to get it took off can u pleasde help me
there are two methods you can try.
Method 1
If you have the administrator account password for the local computer and the best way to uninstall K9 web filter from the local computer is to re-install it! Re-install k9 web protection will simply get you a new license code and a new password you can enter without the need of old password.
1.Open K9 web protection website 2.Click "get K9 NOW" tab on the top-left 3.Fill out the information and your email. 4.Download the K9 Web protection software from the link included in the email and keep a copy of the license. 5.Grab a version of the K9 web protection installed on your computer, a Google search should do the job. 6.Open "Task Manager" by press (Ctrl+Alt+Delete) and end the process K9filter found in the "Process" tab. 7.Now, you can safely delete the K9 web protection program files. Open computer explorer and go to the folder where K9 is originally installed. It can be found mostly at C:\Program Files/Blue Coat k9 Web Protection. 8.Remove the contents of the folder but not the folder. 9.Run the K9 web protection setup/installer file which has the same version as the one you just delete 10.Provide the license and create your new password 11.Point the installation folder to the same folder you just empty the contents earlier on 12.Now you can have a re-installed K9 web protection with a password you know. How do you uninstall K9 web protection now? Use the new password you just created If something goes wrong, install the K9 web protection program downloaded from Step 4.
Method 2
Reboot Windows into safe mode: restart your computer and hold "F8? key until you see the menu to choose "Safe Mode" Login to windows and go to "Program Files" directory and delete the K9 folder manually (delete only the contents but leave the folder) Click "Start"->"Run" and type "msconfig" Check the tab "Services" and tab "Startup" Un-check anything that is related to k9 If somehow this method is messed up, try to download K9 again to at least restore your previous installation. If this still does not work, try to install Revo Uninstaller.
Here is a video tutorial
Aug 24, 2011 | Dell Inspiron 1501 Notebook
Need instructions to program and operate my Omega Excalibur K9 car 3-button remote entry.
Your best bet for this would be to go to the Omega website. Be sure you ahve your make and model number of the alarm. Good luck and please rate. Use the link below to retrieve your manual.
www.caralarm.com/manuals.asp
Mar 15, 2010 | Vehicle Parts & Accessories
Only one of my my k-9 mundial keyless work the other seems fine but wont activate.
Try to reprogram the remotes to the alarm. Have your vehicle key and both remotes ready. The way to do this is as follows:
1. Turn ignition key to run position.
2. Within ten seconds push the valet button 5 times.
3. The siren will give a chirp, indicating that you are in programming mode.
4. Press the large button on the first remote. A chirp will be given as confirmation.
5. Press the large button on the second remote. A chirp will be given as confirmation.
6. Turn off ignition and remove key. Alarm will give long chirp indicating exiting program.
7. Try remotes. Both should be working.
For the next 48 hours, every time the vehicle is starting the siren will chirp indicating that remotes have been programmed. After 48 hours this feature will turn itself off. Also keep an eye on the alarm light as it will also blink the number of times as remotes are programmed every time the ignition is turn on.
Hope this information helps. Please rate. Thank you.
Mar 04, 2010 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
Disable k9 web protection?
Yes, there is a technical way to disable K9
1. Go to K9's Web site, and download a copy of K9 -& get a new license
2. Go to your Program files on your hardrive, and delete the FILES that are in the K9 Folder.
3. Empty your recycle bin
4. Reinstall K9, enter a new password, complete install program
5. That is it! -you can now uninstall K9 or set it accordingly
Just some advice from someone in the same situation!
Dec 13, 2009 | Dell Computers & Internet
I lost my remote for my viper 350 hv,and when i used my key to open the door the alarm went off,and disconnect the viper box,and bought a new remote,and when im trying to program my new remote and plug my...
You have to turn your ignition on and press the valet button switch, to turn off the alarm. Then, you have to use that same valet button to learn the remote to your alarm, following the steps in the installation manual.
Sep 20, 2009 | Viper Security and Remote Start System...
Car alarm
Contact K9 directly and ask them if they could send you a user manual.
Aug 06, 2009 | Chevrolet Caprice Classic Cars & Trucks
Excalibur. K9-MUNDIAL-SS Entry Level Auto Alarm with Dual Zone Shock Sensor Logo
1,001 people viewed this question
Top Dual Electronics Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Dual Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
