Whirlpool top load washer does not spin. Does agitate and drain. Won't spin with load noise, Sort of the same noise the timer makes when a load has finished, except it's constant.
Hi, the likely problem here is a bad coupling. Here are the directions for a bad coupling. Kenmore's, Whirlpool's and Ropers are direct drive machines this means they don't have a belt. Instead the transmission is connected directly to the motor via a coupling. This is what a coupling looks like:
To confirm this pull the machine forward enough that you can lean it back and it will stand back under it's own weight. Wedge something underneath the chassis so it does not fall on you while your accessing the bottom. Go under the Machine and locate the motor, You will see the pump connected to the motor connected to the transmission. 1. Unplug the wire harness from the motor then. 2. Use a screw driver remove the 2 clips holding the pump in place and remove or push the pump out of the way. 3. You will need to remove the 2 screws from the brackets holding the Motor in place with a nut driver. 4. With a screwdriver remove the 2 clips holding the motor in place (be careful to support the motor as the clips comes off) 5. remove the motor and drop it onto the floor. Now you will see the coupling..one side on the motor the other side on the transmission the rubber connector in between. Replace the coupling if broken or worn and reassemble the washer in reverse order. Now you should be all set. Be aware you may smell rubber on the first couple loads this is normal after replacing a coupling.
If you have any other questions please feel free to comment. Mike
Testimonial: "Mike was right on. I followed his easy step by step instructions and found the broken coupler. Replaced the coupler and everything works great."
