Question about Mitsubishi WS-55613 55" Rear Projection HDTV
REMOVE speaker grill off tv?
"First thing to do is remove front speaker grill--" HOW?
Posted by lynnedltorre on
SD Tech
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
The front speaker grill on the WS-55613 will be one of two types
!) if it is a single plastic piece with gray cloth all the way across beneath the screen--it pulls out---held in by plastic pegs--start at right or left side and pull it free.
2) some versions have two smaller grills--one on either side---they pull out and this type has a wood plate (usually black) held in with four or more screws---you remove the two small grills by pulling them out and to get the inspection plate off you remove the screws holding it.
Let me know if you have questions.
If this helped you rate this information as I do this here for free.
SD TECH
Posted on Dec 26, 2009
Where i bulb located on a mitsubishi wd 62525 rear progection hd tv?
Through the front of the TV. Remove the speaker grille (IT SNAPS OFF & ON) & there is a lamp cover with 3 screws holding it in place, near the left speaker.
That lamp part#: 915P020010 $49.00 TO $100.00
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-62525
Jun 03, 2014 | Philips 60PP9202 60" Rear Projection...
I can't remove the speakers from my Harman Kardon Go + play, is there a trick to do it?
You can remove the grill in front of the speakers by using 2 mini mini screw driver one to pry it out little by little while the other to hold it from going back in .There are noscrews holding the grill.They are held by 4 clamps which are the grill inner end bend abit out thats all. So if you pry it will give way not to worry the grill is made of a hard aluminium material it just needs care in order not to scratch the paint surface and aluminium ring around it,use a soft cloth to protect the ring when prying.Remember this aluminium ring wont come out its only the grey grill that will. This thing is worth saving because it sounds great even after speaker repair.Yes where i am in Idonesia there are people who are profesionals at repairing speakers that are torn out like our harman.(torn due to age around the speaker cone).i paid 15 usd to get the both of them repaired and its the best 15 dollars i have ever spent.Cause now it could not have sounded any newer the bass is back the balance is pure harman again
Oct 22, 2012 | Harman Kardon Go + Play Portable Speaker...
Need instructions to replace the passenger side mirror and the driver side tail light on a 1999 Ford Taurus 4-door sedan. Thank you, Gary S.
Section 01-09: Mirrors, Rear View 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Mirror, Power-Outside Rear View Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942). Refer to Section 01-05.
  1. Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
  1. Remove two screws from cover assembly.
  1. Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
  1. Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
Item Part Number Description 1 17682 Outside Rear View Mirror 2 N621906-S36 Nut (3 Req'd) 3 F8DB-17D699-
AAW Cover Assembly Rear Substrate-LH 3 F8DB-17D698-
AAW Cover Assembly Rear Substrate-RH 4 N808968 Screw 5 F8DB-18B984-
AAW Speaker Grille-Standard (No Badge)-LH 5 F8DB-18985-
AAW Speaker Grille-Standard (No Badge)-RH 5 F8DB-18K901-
BAW Speaker Grille-Mach-LH 5 F8DB-18978-
BAW Speaker Grille-Mach-RH 5 F8DB-238A35-
AAW Speaker Grille-Blank (No Speaker)-LH 5 F8DB-238A34-
AAW Speaker Grille-Blank (No Speaker)-RH A - Tighten to 6-8 Nm (54-70 lb-in) ------------------
Trim Panel, Door Front
Removal
  1. Remove cover behind inside door handle.
  1. Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
  1. Remove three screws retaining front door trim panel to front door.
  1. NOTE: Do not attempt to remove more than one pushpin at a time.
    Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
  1. Disconnect electrical connectors as necessary. Refer to Section 01-14A.
Installation
  1. Follow removal procedure in reverse order.
  1. Replace all pushpins with new pushpins (N808994-S).
Front Door Trim Panel
Jan 14, 2011 | 1999 Ford Taurus
Remove Speaker Grille from Sony KP-65WV700
So you got the six screws undone, great! Now you can pop off the front speaker grill. The easiest way is to work your hand along the top and bottom to pop the plastic out of the "holders"
If what you are describing to me is the main wires still attached to the rest of the TV. So don't pull it out too far! If you do it right you won't have to unplug the wires, and save yourself some hassle... with this TV you'll have to pull it out JUST ENOUGH to get access to the carboard/masonite backing, removing such will give you full access to the six controls.
Adjust from there! Sorry for the wait, and I hope this helped out!
May 30, 2009 | Sony KP-51HW40 51" Rear Projection...
Ic location
they are located in the front of the TV behind the speaker grille. Remove the screws from behind that secure the speaker grille and the two inside the small door below the control buttons, Then you will see a small access panel remove that and the ICs are on the skinny board up front. Do not remove the rear panel on your model with the cord plugged in or it will destroy the HD circuits
May 29, 2009 | JVC AV-48WP74 48" Rear Projection...
Where is the lamp for sonykf60we610
Lamp is located at lower front of TV and you need to remove lower front speaker grill to get access there, remove lamp cover then pull out lamp.
Click Sony Support to download Lamp replacement procedure guide that has all necessary details for KF-60WE610 TV.
Apr 27, 2009 | Sony LAMP BLOCK XL2100U Projector Lamp
How do I remove the cloth grill cover from the front of speaker?
Some speaker manufacturers design their boxes with non-removable front grills. Be thankful that you can remove the back because I've seen these sealed as well. Once inside, the speakers should be mounted from the inside (mounting screws on inside) compared to front mounted. IF they are not then either you're not using the proper method to remove the grill OR it's glued in place and will require breaking the glue bond to release the grill. One note to remember...non-removable grills can mean the manufacturer has something to hide.
Mar 22, 2009 | Philips Audio Players & Recorders
Tv mitsubishi ws55311
Remove front lower speaker grill,then remove access panel =
unplug white connector ( goes to front controls )......Does the set
work now with remote ?...= bad tactil switch on front panel......T.
Apr 23, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Replacing front and rear speakers in a 1999 Mazda Protege
Whats the problem?
Back - Remove speaker grill, unscrew, climb in trunk, unplug - remove.
Front - Remove speaker grill, unscrew, pull out, unplug. If you have problems remove window winders and door skins
Dec 15, 2007 | Car Audio & Video
PT47QWX42 Projection TV Panasonic IS GREEN
Yes but sometimes you have to remove a cover behind the grille to get to them.
Sep 14, 2007 | Televison & Video
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
Paul Bade
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
