RCA P52937 52" Rear Projection Television Logo
Question about RCA P52937 52" Rear Projection Television
RCA Home Theater Premiere 36" TV comes on automatically
We have a 36" RCA Home Theater Premeire TV that does not have a alarm to turn TV on but the TV comes on by itself daily at the same time. We have unplugged the TV for days at at time tihinking it woudl reset itself but the same problem occurs..
Any suggestions..
Posted by sgriff63 on
SD Tech
    Top Expert:
  • RCA Master
  • 14,553 Answers
Only two possible reasons I can think of for this--
ONE: you have looked in the customer menu and there is no item listed as Timer?
TWO: Does THIS SET HAVE THE GUIDE PLUS LOGO ON THE FRONT OF THE SET? IF IT HAS THE GUIDE PLUS--YOU WILL FIND IT IN THE MENU ALSO---
LET me know if it has the guide plus feature and I can tell you how to end the problem--most of these the set will come on at the same odd time and usually with volume up high.
SD TECH
Posted on Dec 26, 2009
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
HOW DO YOU GET TV AUDIO TO MY HOME THEATER?
For analog audio output use the L (White) and R (Red) RCA/Phono coax jacks to output to your Home Theater. Other option is to use the headphone jack wired to the home theater, however use of this will switch off any sound coming from the TV.
If the Home Theater supports digital inputs, use one of these connectors, Orange/Black RCA jacks, Toslink (Optical), HDMI. For nice pictures do a search for images in google/yahoo with the connector type.
So basically look for output connectors on the TV and match it with the same type of connector on you Home Theater input.
RCA LCD Flat Panel HDTV and RCA Home Theater System--No sound
Video comes from external device to TV - OUT on device and IN on TV.
Sound connects by the red/white cable set (or HDMI). Place set in Audio OUT ports on TV and Audio IN ports on DVD. Then select AUX IN on DVD.
1helpful
Should i mute the volume on my tv now that i have a home theater system set up?
No. Here is why, you are sending the sound through an audio left and right on the theater system therefore the audio part of the tv will go mute automatically. for example your dvd player left and right audio will be outputed through you theater system and video to the TV...
Rca f36648 & rca HOME THEATER
Have you tried just hoooking up the DVD player by itself? Is the DVD player output setting correct? Also, make sure the "video input" is set for the correct channel that you are viewing (i.e. Channel 3).
36" RCA Home Theater Tv
sounds like flyback (high voltage transformer)shorted
2helpful
4answers
unplug the TV for 4 hrs. and let it reset to factory settings and then start from there scan for channel line up in the menu.
RCA rear projection tv
Dir TV projection Techcions, I own RCA Model:P52937 Chassis No.PTK195M26B. After a big flood here in Chicago, my basement got flooded and my projection TV was in water up to 1 foot. Befor I turned it on, I dreid it out perfectly, then, I turned it on, and a couple components from the power supply got burned up to the point where I am not able to read the part numbers that are on it. I was wondering if you have this kind of chassis and model service manual for this projection TV, or conponet part number i location 101 on mother boatd power supply. Thank you in advance, Darius If you prefeer, you may call my cell phone: 773-875-3926
Top RCA Televison & Video Experts
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
